Follow up on post with additional questions and images- gpu memory nsight compute wsl 2
Hi everyone, just wanted to follow up with to that post with some additional details and images
old-post
When i run the following code
nvcc -o 00 00\ nvtx_matmul.cu -lnvToolsExt
nsys profile --stats=true ./00
The ncu-ui app i use to profile
shows the following
as u can see
it does not seem to be showing the cuda HW section at all
What is interesting is
The setting to access performance counters is enabled on windows.
Suspecting a wsl based issue
i tried compiling it on windows
00_nvtx_matmul.cu
tmpxft_00003808_00000000-10_00_nvtx_matmul.cudafe1.cpp
LINK : fatal error LNK1181: cannot open input file 'nvToolsExt.lib'
PS C:\Users\aryan\Downloads\cuda_project>
Which is confusing to me because I thought nvtx was included with the cuda toolkit installation.
i installed cuda toolkit both in wsl and on widnows
and on wsl
[4/8] Executing ‘osrt_sum’ stats report
the following line has data associated with whereas on windows it does not(also the nvtx compilation succeeds on wsl)
It succeeds when i do not link the -lnv tools text command
It does show the cuda HW module, but under threads it shows msedge.exe, and crbrowser and things like that which are not expected in the profiling of the code I am doing
Some help to debug all these issues would be much appreciated. i would be happy to provide anything needed from my side
I would much like to be running all my code on wsl rather than have to be utilizing windows for all my tasks
see notes on GPU memory not recognized for the code - nsight compute
Replied on the post under https://forums.developer.nvidia.com/t/gpu-memory-not-recognized-for-the-code-nsight-compute/323099/6
