I have an NVMe SSD connected by USB on the Jetson Nano with this adapter. The jetson recognize well the disk I can do my partitioning and so on, no problem. I followed all steps mentioned by @dirk.lueth but when I do the step 9 (copyRootToUSB) I get some errors like :“impossible to write : read-only memory” and finaly I can’t edit extlinux.conf even if I’m root… When I use the command lsblk, I see that my sda1 is not in read only so I don’t understand and I’m stucked here.
Do you think that the program copyRootToUSB is not able to copy the system correctly because of my configuration ?
Does anyone know why my disk goes into read-only mode when I run the program?
All help is welcome
