hi everyone, i just started learning cuda. here is the code inside my kernel.
int index = threadIdx.x;
for(int i = 0; i < 10; i++)
printf("%d\n", index);
the kernel has 1 block with 130 threads. when i used 10 iterations for each thread, it works. however, when i used 100 or more, it printed out only 4096 elements. is there any limit for loop inside kernel?
thanks in advance.
here is my device query:
Device 0: “GeForce GT 430”
CUDA Driver Version / Runtime Version 4.0 / 4.0
CUDA Capability Major/Minor version number: 2.1
Total amount of global memory: 1023 MBytes (1072889856 bytes)
( 2) Multiprocessors x (48) CUDA Cores/MP: 96 CUDA Cores
GPU Clock Speed: 1.40 GHz
Memory Clock rate: 600.00 Mhz
Memory Bus Width: 64-bit
L2 Cache Size: 131072 bytes
Max Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536,65535), 3D=(2048,2048,2048)
Max Layered Texture Size (dim) x layers 1D=(16384) x 2048, 2D=(16384,16384) x 2048
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 65535
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Concurrent kernel execution: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support enabled: No
Device is using TCC driver mode: No
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 4.0, CUDA Runtime Version = 4.0, NumDevs = 1, Device = GeForce GT 430
