Im on my carrier project and there is some HW changing from Jetson TX2.
I have erased the EEPROM for configuration and I have found a important notice on that case.
There should be a change on Linux_for_Tegra/bootloader/tegra234-mb2-bct-common.dtsi.
The cvb_eeprom_read_size changed to be 0
but the document is for tegra23x, and mine is based on tegra186…
I could not find out any dtsi file corresponding to this file at /Linux_for_Tegra/bootloader.
Which file and where can I found to be modified for the case of removed EEPROM?
Sorry, my expression is not exactly accurate.
I have removed the EEPRom on my carrier board corresponding to the chip on theTX2 reference carrier board, not TX2 module.
Thank you.
