I was a bit disappointed as all my 3 USB web cameras did not work with Nano.
They display fine with fswebcam app (but not with Cheese).
I did not want to spend more money to buy a new one.
Anyways… It was hard for me to find a way to use videos files run samples. After some digging I finally put together the following code:
Run run use the command: “python3 mv_detection.py <your_video_file>”
Know bug: If you click over the window while playing the program hangs. Need to kill the process in order to terminate/close it.
Note that in my initial post for some reason the code is missing “This file has been truncated” (not sure why is truncated). Click “show original” to see the entire code.
Please share brand and model ID of the cameras. Not sure but it sounds like it should be run as RTSP sources. With more detail we can check and advise.
