Force array to be shared in OpenACC
Hello.
I’m trying to use CUDA pointers in a simple OpenACC region.
Following is the code.
!$ACC DATA PRESENT(cuAxialRay)
!$ACC KERNELS
DO ipin = 1, nxy
  DO izf = myzbf, myzef
    rhsq = 1.0 / (cuAxialRay%LenSeg(izf) ** 2)
    idx = (izf - myzbf) * ng + (ipin - 1) * ng * nzf
	DO ig = 1, ng
      phisSlopef(idx + ig) = phimf(ig, izf, ipin) * rhsq
    ENDDO
  ENDDO
ENDDO
!$ACC END KERNELS
!$ACC END DATA
phisSlopef and phimf are both CUDA pointers.
When I try to compile the code section, compiler says:
214, Generating present(cuaxialray)
216, Parallelization would require privatization of array phisslopef(:)
217, Parallelization would require privatization of array phisslopef(:)
Accelerator kernel generated
Generating Tesla code
220, Parallelization would require privatization of array phisslopef(:)
But the loop is safe from data-race, so I want phisslopef to be public.
How do I force it?
Hi CNJ,
How do I force it?
You would add the “independent” clause to the loop directive to assert to the compiler that the loop does not contain dependencies.
!$ACC KERNELS
!$ACC LOOP INDPENDENT
DO ipin = 1, nxy
   DO ig = 1, ng
    ENDDO
  ENDDO
ENDDO
!$ACC END KERNELS
!$ACC END DATA
-Mat
