Subject / Issue Description:
Custom Carrier Board for Jetson Thor Fails to Boot / No HDMI Output (No UART Debug Header Reserved)
Current Symptoms & Troubleshooting Status:
Our custom-designed carrier board fails to boot and has no display on HDMI. Since we do not have a reserved UART debug header, we are observing the following symptoms and would like guidance on what to check next:
Power-on Sequence & Voltages: Verified that the power-on sequence and voltage levels meet specifications (confirmed to match the Jetson Thor reference carrier board).
Force Recovery Pin: FORCE_RECOVERY_N is not pulled low, but connecting the board via USB shows an APX device in the system. We verified that it is HIGH during SYS_RESET_N inactive (confirmed to match the Jetson Thor reference carrier board).
System Overcurrent / Power Rail Behavior (SYSTEM_OC_N): With no external devices connected and SYSTEM_OC_N pulled high with a 47Kohm resistor to 1.8V, the voltage starts at 1.8V on boot, but after a short while, it drops to 0.5V, Reducing the pull-up resistor to 2.2Kohm ,similarly causes the voltage to drop to 1.6V after a short while.On the Jetson Thor reference carrier board, this signal remains steadily at 1.8V.
Question:
Based on these findings, what else should we check next?
Would suggest get UART log to clarify what is happening on the system. Powering on the system while FORCE_RECOVERY_N is pulled low is a hardware behavior, it is impossible it is not in recovery mode. Would suggest catch UART log to get more information.
As mentioned earlier, we unfortunately forgot to reserve a UART debug header on our design, so we cannot capture logs via UART right away.
Could you please provide the component location on the T4000 SOM PCBA where we can solder jumper wires to access the UART debug port?
if force power pin is keep high, but system still into recovery mode
the boot process is follow below? our design is on Current boot slot is invalid ?(yes) and The other slot is Yes invalid ?(yes) so into recovery?
hiwata
October 16, 2026, 2:23am
9
Have you confirmed that this CVM works correctly on the developer kit?
On your carrier board, are the following pins properly tied to GND?
GPIO56/ BOOT_CHAIN_SEL
GPIO39 / BOOT_CHAIN_0
I2S2_CLK / BOOT_CHAIN_1
Thank you,
Are you sure your board is able to get flashed in this situation? I mean in your so-called recovery mode situation.
Dear NV teams,
I’m the software member working with jerry.wu3.
We have now enabled the UART3_TX_DEBUG from T4000 module.
However, we found that the system seems to reset during MB1 before entering MB2.
[0000.097] C> rst_source: 0x0, rst_level: 0x0
[0000.093] C> rst_source: 0x39, rst_level: 0x1
[0000.093] C> rst_source: 0x3c, rst_level: 0x1
Could you please help us figure out the issue?
Best Regards,
Red
Full UART3_TX_DEBUG logs:
[0000.095] I> MB1 (version: 0.23.0.2-t264-75019003-378e427f)
[0000.095] C> Boot-mode : Coldboot
[0000.095] C> MB1 last_boot_error: 0x0
[0000.095] I> Entry timestamp: 0x00013807
[0000.101] I> BR-BCT: preprod_dev_sign: 0
[0000.105] I> Socket mask: 0x1
[0000.108] I> Socket id: 0
[0000.111] I> Chip supports UFS HS mode
[0000.114] I> BR last_boot_error0: 0x0
[0000.117] I> BR last_boot_error1: 0x0
[0000.121] I> BR last_boot_error2: 0x0
[0000.124] I> NVBCT is initialized
[0000.128] I> Task: PSC Mailbox init
[0000.131] I> Task: Bootchain select WAR set
[0000.135] I> Task: Bootchain update marker
[0000.139] I> Task: Send error information to MCU
[0000.143] I> Task: CRC check
[0000.146] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.153] I> Task: CRC Integrity check
[0000.157] I> Task: Bootrom patch record validation and params check
[0000.163] I> Task: CRC Integrity check
[0000.167] I> Task: SMN Transfer check
[0000.170] I> Task: Initialize UTMI PLL
[0000.174] I> Task: Initialize REF_UFS PLL
[0000.179] I> Task: Crypto init
[0000.180] I> Task: Boost clocks
[0000.184] I> tegrabl_clk_print_clock_freq not supported
[0000.188] I> mb1_clocks_soc_boost_clocks: Switch BPMP_CPU_NIC to NAFLL
[0000.195] I> mb1_clocks_soc_boost_clocks: CLK_SOURCE_AXI_CBB 0x0, bct.axi_cbb_clk_divisor 0
[0000.203] I> Task: Perform MB1 KAT tests
[0000.207] I> Task: Secure debug controls
[0000.210] I> Task: Program NV master stream id
[0000.215] I> Task: Enabling and initialization of MSS Bandwidth limiter
[0000.221] I> No request to configure MBWT settings for any PC!
[0000.227] I> Task: Verify boot mode
[0000.230] I> Task: Alias fuses
[0000.234] I> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.240] I> Task: Print SKU type
[0000.243] I> SKU: INVALID
[0000.246] I> Task: Recalibrate SOC vmon
[0000.250] I> vmon adc_cal_revision 4, min_adc_fuse_rev 1
[0000.255] I> SOC VMON: min_reset 0, max_reset 0
[0000.259] I> SOC VMON ADC_SETUP: 0x00000000 to 0xc0000000
[0000.264] I> SOC VMON: Vmon re-calibration and fine tuning done
[0000.270] I> SOC VMON: min_reset 0, max_reset 0
[0000.274] I> Task: Select UFS ref clk
[0000.278] I> UFS device reference clock programmed to 26 MHz
[0000.283] I> Task: PMC AUX Clamp
[0000.287] I> Task: UPHY lane resets
[0000.290] I> Task: UPHY init
[0000.292] I> Configuring uphy in rate B
[0000.298] I> tegrabl_clk_print_clock_freq not supported
[0000.301] I> PLL3 ownership is assigned to PCIE
[0000.307] I> tegrabl_clk_print_clock_freq not supported
[0000.312] I> mphy_nv_calib_rev : 0, mphy_nv_calib_aux_val : 0
[0000.317] I> Enabling PLL with id : 3
[0000.320] I> Enabling PLL with id : 4
[0000.324] I> Skipping uphy_instance 1. Not supported yet
[0000.328] I> Skipping uphy_instance 2. Not supported yet
[0000.334] I> Task: Boot device init
[0000.337] I> Boot_device: QSPI_FLASH instance: 0
[0000.341] I> Using QSPI flash params from bct!!
[0000.346] I> PLLC is already locked
[0000.349] I> Qspi clock source : pllc_out0
[0000.353] I> QSPI Flash: Macronix 64MB at index: 5
[0000.358] I> QSPI-0l initialized successfully
[0000.362] I> Task: TSC init
[0000.365] I> Task: Load membct
[0000.367] C> RAM_CODE 0x0
[0000.370] I> Loading MEMBCT
[0000.372] I> Slot: 0
[0000.375] I> Binary[0] block-3840 (partition size: 0x60000)
[0000.380] I> Binary name: MEM-BCT-0
[0000.383] I> Size of crypto header is 8192
[0000.387] I> Size of crypto header is 8192
[0000.391] I> BCH of MEM-BCT-0 read from storage
[0000.396] I> MEM-BCT-0 header integrity check is success
[0000.400] I> Binary magic in BCH component 0 is MEM0
[0000.405] I> component binary type is 0
[0000.410] I> MEM-BCT-0 binary is read from storage
[0000.414] I> MEM-BCT-0 binary integrity check is success
[0000.419] C> RAM_CODE 0x0
[0000.424] C> RAM_CODE 0x0
[0000.425] I> Task: Load Page retirement list
[0000.428] I> DRAM ECC PRL is disabled
[0000.431] I> Task: SDRAM params override
[0000.435] I> Before update: MssEncryptGenKeys: 0x20000000, MssEncryptDistKeys: 0x00000000, McDefaultEncr: 0x00000000
[0000.445] I> Post update: MssEncryptGenKeys: 0x2000000f, MssEncryptDistKeys: 0x000f000f, McDefaultEncr: 0x80000100
[0000.456] I> Task: Save mem-bct info
[0000.459] I> Task: Carveout allocate
[0000.463] I> GR carveout will not be allocated
[0000.467] I> RCM blob carveout will not be allocated
[0000.485] I> Task: Enable WDT 5th expiry
[0000.485] I> Re-Enabling WDT
[0000.485] I> Task: I2C register
[0000.485] I> Task: Fuse Dump
[0000.485] I> opt_ucf_cluster_disable = 0x600
[0000.488] I> opt_c2c_disable = 0x1
[0000.491] I> opt_gpc_disable = 0x4
[0000.494] I> opt_tpc_disable = 0x7c0
[0000.497] I> opt_fbp_disable = 0x2
[0000.501] I> opt_nvdec_disable = 0x1
[0000.504] I> opt_nvenc_disable = 0x1
[0000.508] I> opt_isp_disable = 0x1
[0000.511] I> opt_mgbe_disable = 0x8
[0000.514] I> opt_fsi_disable = 0x1
[0000.517] I> fsi_ram_repair_enable = 0x0
[0000.521] I> opt_mss_disable = 0x0
[0000.524] I> OPT_IGPU_RESERVED = 0x165
[0000.528] C> BOOT_NV_INFO = 0x30f788
[0000.531] I> BOOTROM_PATCH_VERSION = 0x3
[0000.535] I> PSCROM_PATCH_VERSION = 0x7
[0000.539] I> OPT_ADC_CAL_FUSE_REV = 0x4
[0000.543] I> OPT_SW_L1MAINRST_ENABLE = 0x1
[0000.546] I> OPT_EMPD_CALIB_REV = 0x2
[0000.550] I> OPT_EMPD_CALIB = 0x784
[0000.553] I> OPT_CSDC_ENABLE = 0x0
[0000.556] I> OPT_PV_DAC_CTRL_REV = 0x3
[0000.560] I> OPT_PV_BG_CTRL_DAC_OFFSETS_REV = 0x3
[0000.565] I> opt_ECC_en = 0x0
[0000.567] I> SKU_INFO = 0xe2 (PROD)
[0000.571] C> OPT_SAMPLE_TYPE = 0x3
[0000.574] C> opt_subrevision = 0x2
[0000.577] I> opt_lot_code_0 = 0x103c4109 (rdl)
[0000.581] I> opt_ft_rev = 0x40
[0000.584] I> opt_fuse_file_version = v57
[0000.588] I> slt_info = 0x3
[0000.591] I> cpu_speedo_calib = 0x840
[0000.594] I> cpu_ht_iddq_calib = 0x5a
[0000.598] I> soc_speedo_calib = 0x815
[0000.601] I> soc_ht_iddq_calib = 0x4d
[0000.605] I> gpu_speedo_calib = 0x836
[0000.608] I> gpu_ht_iddq_calib = 0x124
[0000.612] I> mss_speedo_calib = 0x835
[0000.615] I> mss_ht_iddq_calib = 0x1401
[0000.619] I> Task: POD config init
[0000.622] I> Task: Reset FSI
[0000.625] I> Task: Update FSI scratch with fuse data
[0000.629] I> Task: Load and upda яэяв яяв
[0000.091] I> MB1 (version: 0.23.0.2-t264-75019003-378e427f)
[0000.091] C> Boot-mode : Coldboot
[0000.091] C> MB1 last_boot_error: 0x0
[0000.091] I> Entry timestamp: 0x000127c9
[0000.097] I> BR-BCT: preprod_dev_sign: 0
[0000.101] I> Socket mask: 0x1
[0000.104] I> Socket id: 0
[0000.106] I> Chip supports UFS HS mode
[0000.110] I> BR last_boot_error0: 0x0
[0000.113] I> BR last_boot_error1: 0x0
[0000.117] I> BR last_boot_error2: 0x0
[0000.120] яэяв яяв
[0000.090] I> MB1 (version: 0.23.0.2-t264-75019003-378e427f)
[0000.091] I> Entry timestamp: 0x00012726
[0000.120] I> NVBCT is initialized
[0000.123] I> Task: PSC Mailbox init
[0000.127] I> Task: Bootchain select WAR set
[0000.131] I> Task: Bootchain update marker
[0000.135] I> Task: Send error information to MCU
[0000.139] E> MB1 Boot Progress code: 0x1000005
[0000.144] E> MB1 Error code: 0x0
[0000.146] I> Task: CRC check
[0000.149] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.156] I> Task: CRC Integrity check
[0000.160] I> Task: Bootrom patch record validation and params check
[0000.166] I> Task: CRC Integrity check
[0000.170] I> Task: SMN Transfer check
[0000.173] I> Task: Initialize UTMI PLL
[0000.177] I> Task: Initialize REF_UFS PLL
[0000.182] I> Task: Crypto init
[0000.183] I> Task: Boost clocks
[0000.187] I> tegrabl_clk_print_clock_freq not supported
[0000.191] I> mb1_clocks_soc_boost_clocks: Switch BPMP_CPU_NIC to NAFLL
[0000.199] I> mb1_clocks_soc_boost_clocks: CLK_SOURCE_AXI_CBB 0x0, bct.axi_cbb_clk_divisor 0
[0000.206] I> Task: Perform MB1 KAT tests
[0000.211] I> Task: Secure debug controls
[0000.214] I> Task: Program NV master stream id
[0000.218] I> Task: Enabling and initialization of MSS Bandwidth limiter
[0000.224] I> No request to configure MBWT settings for any PC!
[0000.230] I> Task: Verify boot mode
[0000.233] I> Task: Alias fuses
[0000.237] I> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.243] I> Task: Print SKU type
[0000.247] I> SKU: INVALID
[0000.249] I> Task: Recalibrate SOC vmon
[0000.253] I> vmon adc_cal_revision 4, min_adc_fuse_rev 1
[0000.258] I> SOC VMON: min_reset 0, max_reset 0
[0000.262] I> SOC VMON ADC_SETUP: 0x00000000 to 0xc0000000
[0000.268] I> SOC VMON: Vmon re-calibration and fine tuning done
[0000.273] I> SOC VMON: min_reset 0, max_reset 0
[0000.278] I> Task: Select UFS ref clk
[0000.281] I> UFS device reference clock programmed to 26 MHz
[0000.286] I> Task: PMC AUX Clamp
[0000.290] I> Task: UPHY lane resets
[0000.293] I> Task: UPHY init
[0000.295] I> Configuring uphy in rate B
[0000.301] I> tegrabl_clk_print_clock_freq not supported
[0000.304] I> PLL3 ownership is assigned to PCIE
[0000.310] I> tegrabl_clk_print_clock_freq not supported
[0000.315] I> mphy_nv_calib_rev : 0, mphy_nv_calib_aux_val : 0
[0000.320] I> Enabling PLL with id : 3
[0000.323] I> Enabling PLL with id : 4
[0000.327] I> Skipping uphy_instance 1. Not supported yet
[0000.331] I> Skipping uphy_instance 2. Not supported yet
[0000.337] I> Task: Boot device init
[0000.340] I> Boot_device: QSPI_FLASH instance: 0
[0000.344] I> Using QSPI flash params from bct!!
[0000.349] I> PLLC is already locked
[0000.352] I> Qspi clock source : pllc_out0
[0000.356] I> QSPI Flash: Macronix 64MB at index: 5
[0000.362] I> QSPI-0l initialized successfully
[0000.365] I> Task: TSC init
[0000.368] I> Task: Load membct
[0000.370] C> RAM_CODE 0x0
[0000.373] I> Loading MEMBCT
[0000.375] I> Slot: 1
[0000.378] I> Binary[0] block-66304 (partition size: 0x60000)
[0000.383] I> Binary name: MEM-BCT-0
[0000.386] I> Size of crypto header is 8192
[0000.390] I> Size of crypto header is 8192
[0000.395] I> BCH of MEM-BCT-0 read from storage
[0000.399] I> MEM-BCT-0 header integrity check is success
[0000.404] I> Binary magic in BCH component 0 is MEM0
[0000.409] I> component binary type is 0
[0000.413] I> MEM-BCT-0 binary is read from storage
[0000.417] I> MEM-BCT-0 binary integrity check is success
[0000.422] C> RAM_CODE 0x0
[0000.427] C> RAM_CODE 0x0
[0000.428] I> Task: Load Page retirement list
[0000.431] I> DRAM ECC PRL is disabled
[0000.434] I> Task: SDRAM params override
[0000.438] I> Before update: MssEncryptGenKeys: 0x20000000, MssEncryptDistKeys: 0x00000000, McDefaultEncr: 0x00000000
[0000.448] I> Post update: MssEncryptGenKeys: 0x2000000f, MssEncryptDistKeys: 0x000f000f, McDefaultEncr: 0x80000100
[0000.459] I> Task: Save mem-bct info
[0000.462] I> Task: Carveout allocate
[0000.466] I> GR carveout will not be allocated
[0000.470] I> RCM blob carveout will not be allocated
[0000.488] I> Task: Enable WDT 5th expiry
[0000.488] I> Re-Enabling WDT
[0000.488] I> Task: I2C register
[0000.488] I> Task: Fuse Dump
[0000.488] I> opt_ucf_cluster_disable = 0x600
[0000.491] I> opt_c2c_disable = 0x1
[0000.494] I> opt_gpc_disable = 0x4
[0000.497] I> opt_tpc_disable = 0x7c0
[0000.501] I> opt_fbp_disable = 0x2
[0000.504] I> opt_nvdec_disable = 0x1
[0000.507] I> opt_nvenc_disable = 0x1
[0000.511] I> opt_isp_disable = 0x1
[0000.514] I> opt_mgbe_disable = 0x8
[0000.517] I> opt_fsi_disable = 0x1
[0000.521] I> fsi_ram_repair_enable = 0x0
[0000.524] I> opt_mss_disable = 0x0
[0000.528] I> OPT_IGPU_RESERVED = 0x165
[0000.531] C> BOOT_NV_INFO = 0x30f788
[0000.535] I> BOOTROM_PATCH_VERSION = 0x3
[0000.538] I> PSCROM_PATCH_VERSION = 0x7
[0000.542] I> OPT_ADC_CAL_FUSE_REV = 0x4
[0000.546] I> OPT_SW_L1MAINRST_ENABLE = 0x1
[0000.550] I> OPT_EMPD_CALIB_REV = 0x2
[0000.553] I> OPT_EMPD_CALIB = 0x784
[0000.556] I> OPT_CSDC_ENABLE = 0x0
[0000.559] I> OPT_PV_DAC_CTRL_REV = 0x3
[0000.563] I> OPT_PV_BG_CTRL_DAC_OFFSETS_REV = 0x3
[0000.568] I> opt_ECC_en = 0x0
[0000.571] I> SKU_INFO = 0xe2 (PROD)
[0000.574] C> OPT_SAMPLE_TYPE = 0x3
[0000.577] C> opt_subrevision = 0x2
[0000.580] I> opt_lot_code_0 = 0x103c4109 (rdl)
[0000.585] I> opt_ft_rev = 0x40
[0000.587] I> opt_fuse_file_version = v57
[0000.591] I> slt_info = 0x3
[0000.594] I> cpu_speedo_calib = 0x840
[0000.597] I> cpu_ht_iddq_calib = 0x5a
[0000.601] I> soc_speedo_calib = 0x815
[0000.604] I> soc_ht_iddq_calib = 0x4d
[0000.608] I> gpu_speedo_calib = 0x836
[0000.611] I> gpu_ht_iddq_calib = 0x124
[0000.615] I> mss_speedo_calib = 0x835
[0000.619] I> mss_ht_iddq_calib = 0x1401
[0000.622] I> Task: POD config init
[0000.625] I> Task: Reset FSI
[0000.628] I> Task: Update FSI scratch with fuse data
[0000.633] I> Task: Load and update яэяв яяв
[0000.090] C> Boot-mode : Coldboot
[0000.091] I> Entry timestamp: 0x000126dd
[0000.120] яэяв яяв
[0000.091] I> Entry timestamp: 0x000128df
[0000.098] I> BR-BCT: preprod_dev_sign: 0
[0000.107] I> Chip supports UFS HS mode
[0000.114] I> BR last_boot_error1: 0x0
[0000.121]
This issue has nothing to do with recovery mode or boot chain.
Is same SOM still able to boot up fine when it is on NV devkit?
thanks for the clarification.
yes, we have tested this SoM on NV devkit before mounting it to the custom-designed carrier board.
It works well on the NV devkit, but failed on the custom-designed carrier board.
hiwata
October 19, 2026, 8:33am
16
Additionally, could you please confirm whether the power supply connection to L53 (SYS_VIN_SV) follows the same arrangement as our reference board?
Thank you,
This CVM boots up normally on the NVIDIA carrier board.
On our carrier board, the following three pins are currently left unconnected (no components are connected):
GPIO56 / BOOT_CHAIN_SEL
L53 (SYS_VIN_SV) is connected to the 3.3V always domain, which is the same arrangement as on the NVIDIA carrier board.
hiwata
October 20, 2026, 2:51am
18
As described in the Design Guide, please tie GPIO56/ BOOT_CHAIN_SEL to GND.
As an additional precaution, please also tile GPIO39 and I2S2_CLK to GND, as shown in our reference design.
Thank you,
Thank you for the suggestion.
We will first try tying GPIO56 / BOOT_CHAIN_SEL, GPIO39 / BOOT_CHAIN_0, and I2S2_CLK / BOOT_CHAIN_1 to GND, following the Design Guide and your reference design, and will share the results once we have verified it.
Thank you,
HI,
after connect GPIO56 / BOOT_CHAIN_SEL, GPIO39 / BOOT_CHAIN_0, and I2S2_CLK / BOOT_CHAIN_1 to GND, the UART log still have same log
hiwata
October 21, 2026, 1:34am
21
Could you please provide the following pins are followed our reference board?
L41 (VM_SLEEP_N): floating
J62 (GND_009): pulled down to GND
A61 (SYSTEM_OC): pulled up to 1.8V
Thank you,
L41 (VM_SLEEP_N): NC(only reserve test point)
J62 (GND_009): connect 0ohm to GND
A61 (SYSTEM_OC): pulled up 2.2K to 1.8V
BTW, check A61 pin(system OC# power will drop 1.8V to 1.62V)
hiwata
October 21, 2026, 3:31am
23
Could you please capture the power-on sequence waveform as shown in Design Guide Figure 5-2?
Please include the following signals:
SYS_VIN_MV
SYS_VIN_HV
VDDIN_PWR_BAD_N
MODULE_POWER_ON
CARRIER_POWER_ON
SYS_RESET_N
L41 (VM_SLEEP_N)
Regarding SYSTEM_OC_N dropping from 1.8V to 1.6V.
This is expected when MB1 is in a reset loop. When the SoC enters POR, the internal 20kΩ pull-down become active, resulting in a voltage divider with your external pull-up.
Thank you,
Hi, update power sequence
NV
Capture name
SYS_VIN_HV
12V
SYS_VIN_MV
5V
VDDIN_PWR_BAD_N
VIN_PWR_BAD
MODULE_POWER_ON
MOUDLE_PWR_ON
CARRIER_POWER_ON
ARRIER_PWR_ON
SYS_RESET_N
SYS_RESET#
PERIPHERAL_RESET_N
SOC_RESET#:
L41(VM_SLEEP_N)
keep low
Spec
Measure
VDDIN_PWR_BAD_N to MOUDLE_POWER_ON
>50ms
104.18ms
MOUDLE_POWER_ON to CARRIER_POWER_ON
<13ms
11.587ms
MOUDLE_POWER_ON to SYS_RESET_N
>15ms
72.944
hiwata
October 21, 2026, 7:24pm
25
Thank you for sharing the waveforms.
Could you please clarify how VIN_PWR_BAD_N is connected on your carrier board?
This signal is pulled up to VDD_5V on the CVM, so we would expect it to rise with VDD_5V. However, the shared waveforms do not appear to show this behavior.
Could you please share the schematics showing the connections to CVM and the power-related circuity?
Thank you,
VIN_PWR_BAD_N is controlled by the SYS_VIN_HV voltage on our carrier board. It stays low until SYS_VIN_HV reaches 6.3V, and goes high once SYS_VIN_HV is at or above 6.3V.
The power circuit schematic is attached as a PDF. Please let me know if anything is missing and I’ll provide it.
Thank you,
for nvidia (power circuit).pdf (199.7 KB)
