force variable in global mem
how can I force a variable to be in global memory? In CUDA I can use the __local keyword but in OpenCL I cannot use __global as variable’s modifier.
I need something like this:
register float4 varReg;
__global float4 varMem;
varReg.x += 1.0f;
varMem.x += 1.0f;
The idea is to reduce the register pressure. I barely update the “varMem” variable, so it could be stored in global memory.
On the other hand, you should allow to use the C “register” keyword to make the oposite.
Yes, the compiler need this kind of human help to make the things right !
thx.
