Forced Induction Shroud
Hi everyone, I saw a few fan shroud designs posted here, but I ended up making my own forced-induction shroud to improve cooling on the DGX Spark/GX10. Just wanted to share it with the community in case anyone else wants to try it:
The main feature of this design is that it does more than just blow air around the outside of the Spark. The spark fits snug inside the shroud, sealing against the intake vent and actively forces air through the chassis, increasing the volume of air being pushed through the entire internal heatsink and out the exhaust. Just going off of “feel” with my hands, the exhaust air volume is easily 2-3x with the addition of the fan so it’s pulling out way more heat this way.
Works great with PLA+ or PETG. No need for anything fancy; just make sure that the XY hole compensation is calibrated on your slicer since it’s a snug fit.
I’m using a 12V Noctua IndustrialPPC 3000 RPM fan, and the difference in temperatures was honestly huge on the Asus GX10.
For testing, I ran the same Minimax H3 Stable Diffusion workload on both an ASUS GX10 and NVIDIA DGX Spark, first completely stock and then again with the fan/shroud running. Same temperature controlled living room for both.
This is what I found:
With the Asus GX10, it got ~18*C cooler temps with the fans on, so overheating isn’t even a possibility.
I provided the Schematics for the automatic fan speed software/firmware in the repository, but there are manual fan controllers if you don’t feel like wiring up the custom circuitry.
Some renders of the shroud:
I only have GX10s and a Nvidia spark in my cluster, so these are the only 2 models I’ve personally tested. Based on visual inspection of CAD files online (Thanks @whpthomas), it seems like it should work for most models. Love to hear confirmation from other users though 😊
Compatibility:
Model Notes
Asus GX10 Works very well
Nvidia DGX Spark Barely works
Gigabyte AI Top Atom Might barely work
HP ZGX Nano Doesn’t look like it has bottom intake port, probably won’t work at all
MSI EdgeXpert Might barely work
Lenovo Thinkstation PGX Might barely work
Note: Working on solutions for the Nvidia/Gigabyte/HP/MSI/Lenovo atm
Now we just need one that supports a pair :)
I have the leg design that allows for stacking, will upload it to the repo soon 🙂
Edit:
I’m going to make my son print this for me, thank you.
UPDATE:
Good news for all models other than the Asus GX10. After prototyping a new version for the Nvidia DGX Spark, I developed a frontal shroud that achieved ~150% better cooling than without the shroud. The updated shroud is designed to also force air through the front which should in theory work for every other spark model out there too.
Very nice. What about adding a raised place for gx10 power brick just under fan? Very little additional heat getting into Asus brick but power adapter not overheating anymore.
You can put the power brick next to the fan, when the fan pulls air in, the movement from the surrounding air should be sufficient for the power brick. I don’t think overheating is an issue on the PSU tbh. But definitely do not put the brick underneath the fan; it will starve the fan of air and reduce cooling capacity. The shroud legs give a gap of 35mm between the fan and the ground which performs very well already, but will still see marginal gains in airflow from a larger gap.
This is a great design. I’m printing one for the DGX right now, and I’m about to order parts from the BOM. I’m a little unclear about how to power the fan. Does the power not come from the OwlTree? Any chance you could include pictures of the wiring rather than the ASCII style diagrams?
Also, have you considered enclosures for the RP2040 and OwlTree built into the shroud? Do you just have them loose?
Do you have a recommended shroud for the Acer version? I think I’ll be buying one of those for my second box.
