Error Log using VERBOSE:
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:5980:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:5980:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6111:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6111:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6112:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6112:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6144:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6144:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6149:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6149:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6114:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6114:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6128:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6128:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6143:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6143:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6148:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6148:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6164:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6164:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6165:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6165:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6174:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6174:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6193:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6193:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6218:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6218:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6249:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6249:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6292:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6292:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6283:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6283:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6293:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6293:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6795:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6795:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6551:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6551:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6720:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6720:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6692:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6692:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6693:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6693:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6695:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6695:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6709:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6709:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6718:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6718:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6719:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6719:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6728:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6728:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6747:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6747:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6772:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6772:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6796:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6796:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6839:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6839:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6830:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6830:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6840:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6840:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7142:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7142:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:6898:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:6898:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7067:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7067:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7039:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7039:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7040:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7040:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7042:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7042:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7056:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7056:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7065:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7065:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7066:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7066:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7075:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7075:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7094:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7094:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7119:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7119:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7143:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7143:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7186:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7186:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7177:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7177:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: IdentityToCastTransform on func:7187:IDENTITY:GPU
[10/03/2023-06:13:33] [TRT] [V] Swap the layer type of func:7187:IDENTITY:GPU from IDENTITY to CAST
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:123:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:123:CONSTANT:GPU with func:135:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:136:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:136:CONSTANT:GPU with func:137:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:138:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:138:CONSTANT:GPU with func:139:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:140:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:140:CONSTANT:GPU with func:141:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:283:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:283:CONSTANT:GPU with func:284:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:298:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:298:CONSTANT:GPU with func:299:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:301:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:301:CONSTANT:GPU with func:304:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:310:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:310:CONSTANT:GPU with func:311:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:325:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:325:CONSTANT:GPU with func:326:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:328:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:328:CONSTANT:GPU with func:331:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:437:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:437:CONSTANT:GPU with func:438:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:439:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:439:CONSTANT:GPU with func:440:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:441:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:441:CONSTANT:GPU with func:442:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:455:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:455:CONSTANT:GPU with func:460:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:456:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:456:CONSTANT:GPU with func:461:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:457:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:457:CONSTANT:GPU with func:462:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:458:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:458:CONSTANT:GPU with func:463:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:459:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:459:CONSTANT:GPU with func:464:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:481:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:481:CONSTANT:GPU with func:482:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:483:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:483:CONSTANT:GPU with func:484:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:485:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:485:CONSTANT:GPU with func:486:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:954:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:954:CONSTANT:GPU with func:955:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:966:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:966:CONSTANT:GPU with func:967:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:977:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:977:CONSTANT:GPU with func:978:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1052:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1052:CONSTANT:GPU with func:1053:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1067:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1067:CONSTANT:GPU with func:1068:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1070:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1070:CONSTANT:GPU with func:1073:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1079:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1079:CONSTANT:GPU with func:1080:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1094:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1094:CONSTANT:GPU with func:1095:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1097:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1097:CONSTANT:GPU with func:1100:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1240:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1240:CONSTANT:GPU with func:1241:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1242:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1242:CONSTANT:GPU with func:1243:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1244:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1244:CONSTANT:GPU with func:1245:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1258:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1258:CONSTANT:GPU with func:1263:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1259:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1259:CONSTANT:GPU with func:1264:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1260:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1260:CONSTANT:GPU with func:1265:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1261:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1261:CONSTANT:GPU with func:1266:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1262:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1262:CONSTANT:GPU with func:1267:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1284:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1284:CONSTANT:GPU with func:1285:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1286:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1286:CONSTANT:GPU with func:1287:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1288:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1288:CONSTANT:GPU with func:1289:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1487:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1487:CONSTANT:GPU with func:1488:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1489:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1489:CONSTANT:GPU with func:1490:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1491:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1491:CONSTANT:GPU with func:1492:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1633:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1633:CONSTANT:GPU with func:1634:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1648:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1648:CONSTANT:GPU with func:1649:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1651:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1651:CONSTANT:GPU with func:1654:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1660:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1660:CONSTANT:GPU with func:1661:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1675:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1675:CONSTANT:GPU with func:1676:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1678:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1678:CONSTANT:GPU with func:1681:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1787:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1787:CONSTANT:GPU with func:1788:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1789:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1789:CONSTANT:GPU with func:1790:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1791:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1791:CONSTANT:GPU with func:1792:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1805:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1805:CONSTANT:GPU with func:1810:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1806:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1806:CONSTANT:GPU with func:1811:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1807:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1807:CONSTANT:GPU with func:1812:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1808:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1808:CONSTANT:GPU with func:1813:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1809:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1809:CONSTANT:GPU with func:1814:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1831:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1831:CONSTANT:GPU with func:1832:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1833:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1833:CONSTANT:GPU with func:1834:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:1835:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:1835:CONSTANT:GPU with func:1836:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2304:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2304:CONSTANT:GPU with func:2305:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2316:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2316:CONSTANT:GPU with func:2317:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2327:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2327:CONSTANT:GPU with func:2328:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2402:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2402:CONSTANT:GPU with func:2403:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2417:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2417:CONSTANT:GPU with func:2418:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2420:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2420:CONSTANT:GPU with func:2423:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2429:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2429:CONSTANT:GPU with func:2430:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2444:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2444:CONSTANT:GPU with func:2445:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2447:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2447:CONSTANT:GPU with func:2450:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2590:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2590:CONSTANT:GPU with func:2591:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2592:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2592:CONSTANT:GPU with func:2593:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2594:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2594:CONSTANT:GPU with func:2595:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2608:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2608:CONSTANT:GPU with func:2613:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2609:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2609:CONSTANT:GPU with func:2614:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2610:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2610:CONSTANT:GPU with func:2615:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2611:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2611:CONSTANT:GPU with func:2616:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2612:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2612:CONSTANT:GPU with func:2617:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2634:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2634:CONSTANT:GPU with func:2635:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2636:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2636:CONSTANT:GPU with func:2637:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2638:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2638:CONSTANT:GPU with func:2639:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2837:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2837:CONSTANT:GPU with func:2838:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2839:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2839:CONSTANT:GPU with func:2840:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2841:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2841:CONSTANT:GPU with func:2842:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2983:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2983:CONSTANT:GPU with func:2984:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:2998:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:2998:CONSTANT:GPU with func:2999:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3001:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3001:CONSTANT:GPU with func:3004:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3010:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3010:CONSTANT:GPU with func:3011:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3025:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3025:CONSTANT:GPU with func:3026:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3028:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3028:CONSTANT:GPU with func:3031:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3137:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3137:CONSTANT:GPU with func:3138:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3139:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3139:CONSTANT:GPU with func:3140:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3141:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3141:CONSTANT:GPU with func:3142:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3155:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3155:CONSTANT:GPU with func:3160:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3156:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3156:CONSTANT:GPU with func:3161:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3157:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3157:CONSTANT:GPU with func:3162:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3158:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3158:CONSTANT:GPU with func:3163:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3159:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3159:CONSTANT:GPU with func:3164:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3181:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3181:CONSTANT:GPU with func:3182:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3183:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3183:CONSTANT:GPU with func:3184:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3185:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3185:CONSTANT:GPU with func:3186:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3654:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3654:CONSTANT:GPU with func:3655:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3666:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3666:CONSTANT:GPU with func:3667:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3677:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3677:CONSTANT:GPU with func:3678:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3752:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3752:CONSTANT:GPU with func:3753:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3767:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3767:CONSTANT:GPU with func:3768:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3770:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3770:CONSTANT:GPU with func:3773:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3779:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3779:CONSTANT:GPU with func:3780:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3794:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3794:CONSTANT:GPU with func:3795:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3797:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3797:CONSTANT:GPU with func:3800:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3940:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3940:CONSTANT:GPU with func:3941:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3942:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3942:CONSTANT:GPU with func:3943:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3944:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3944:CONSTANT:GPU with func:3945:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3958:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3958:CONSTANT:GPU with func:3963:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3959:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3959:CONSTANT:GPU with func:3964:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3960:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3960:CONSTANT:GPU with func:3965:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3961:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3961:CONSTANT:GPU with func:3966:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3962:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3962:CONSTANT:GPU with func:3967:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3984:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3984:CONSTANT:GPU with func:3985:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3986:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3986:CONSTANT:GPU with func:3987:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:3988:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:3988:CONSTANT:GPU with func:3989:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4133:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4133:CONSTANT:GPU with func:4134:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4148:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4148:CONSTANT:GPU with func:4149:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4151:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4151:CONSTANT:GPU with func:4154:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4160:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4160:CONSTANT:GPU with func:4161:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4175:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4175:CONSTANT:GPU with func:4176:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4178:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4178:CONSTANT:GPU with func:4181:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4287:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4287:CONSTANT:GPU with func:4288:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4289:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4289:CONSTANT:GPU with func:4290:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4291:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4291:CONSTANT:GPU with func:4292:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4305:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4305:CONSTANT:GPU with func:4310:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4306:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4306:CONSTANT:GPU with func:4311:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4307:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4307:CONSTANT:GPU with func:4312:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4308:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4308:CONSTANT:GPU with func:4313:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4309:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4309:CONSTANT:GPU with func:4314:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4331:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4331:CONSTANT:GPU with func:4332:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4333:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4333:CONSTANT:GPU with func:4334:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4335:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4335:CONSTANT:GPU with func:4336:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4804:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4804:CONSTANT:GPU with func:4805:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4816:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4816:CONSTANT:GPU with func:4817:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4827:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4827:CONSTANT:GPU with func:4828:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4902:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4902:CONSTANT:GPU with func:4903:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4917:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4917:CONSTANT:GPU with func:4918:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4920:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4920:CONSTANT:GPU with func:4923:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4929:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4929:CONSTANT:GPU with func:4930:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4944:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4944:CONSTANT:GPU with func:4945:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:4947:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:4947:CONSTANT:GPU with func:4950:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5090:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5090:CONSTANT:GPU with func:5091:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5092:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5092:CONSTANT:GPU with func:5093:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5094:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5094:CONSTANT:GPU with func:5095:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5108:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5108:CONSTANT:GPU with func:5113:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5109:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5109:CONSTANT:GPU with func:5114:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5110:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5110:CONSTANT:GPU with func:5115:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5111:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5111:CONSTANT:GPU with func:5116:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5112:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5112:CONSTANT:GPU with func:5117:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5134:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5134:CONSTANT:GPU with func:5135:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5136:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5136:CONSTANT:GPU with func:5137:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5138:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5138:CONSTANT:GPU with func:5139:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5283:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5283:CONSTANT:GPU with func:5284:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5298:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5298:CONSTANT:GPU with func:5299:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5301:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5301:CONSTANT:GPU with func:5304:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5310:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5310:CONSTANT:GPU with func:5311:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5325:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5325:CONSTANT:GPU with func:5326:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5328:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5328:CONSTANT:GPU with func:5331:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5437:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5437:CONSTANT:GPU with func:5438:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5439:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5439:CONSTANT:GPU with func:5440:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5441:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5441:CONSTANT:GPU with func:5442:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5455:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5455:CONSTANT:GPU with func:5460:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5456:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5456:CONSTANT:GPU with func:5461:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5457:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5457:CONSTANT:GPU with func:5462:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5458:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5458:CONSTANT:GPU with func:5463:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5459:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5459:CONSTANT:GPU with func:5464:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5481:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5481:CONSTANT:GPU with func:5482:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5483:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5483:CONSTANT:GPU with func:5484:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5485:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5485:CONSTANT:GPU with func:5486:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5954:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5954:CONSTANT:GPU with func:5955:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5966:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5966:CONSTANT:GPU with func:5967:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:5977:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:5977:CONSTANT:GPU with func:5978:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6052:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6052:CONSTANT:GPU with func:6053:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6067:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6067:CONSTANT:GPU with func:6068:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6070:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6070:CONSTANT:GPU with func:6073:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6079:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6079:CONSTANT:GPU with func:6080:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6094:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6094:CONSTANT:GPU with func:6095:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6097:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6097:CONSTANT:GPU with func:6100:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6240:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6240:CONSTANT:GPU with func:6241:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6242:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6242:CONSTANT:GPU with func:6243:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6244:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6244:CONSTANT:GPU with func:6245:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6258:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6258:CONSTANT:GPU with func:6263:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6259:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6259:CONSTANT:GPU with func:6264:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6260:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6260:CONSTANT:GPU with func:6265:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6261:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6261:CONSTANT:GPU with func:6266:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6262:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6262:CONSTANT:GPU with func:6267:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6284:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6284:CONSTANT:GPU with func:6285:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6286:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6286:CONSTANT:GPU with func:6287:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6288:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6288:CONSTANT:GPU with func:6289:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6487:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6487:CONSTANT:GPU with func:6488:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6489:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6489:CONSTANT:GPU with func:6490:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6491:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6491:CONSTANT:GPU with func:6492:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6633:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6633:CONSTANT:GPU with func:6634:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6648:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6648:CONSTANT:GPU with func:6649:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6651:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6651:CONSTANT:GPU with func:6654:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6660:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6660:CONSTANT:GPU with func:6661:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6675:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6675:CONSTANT:GPU with func:6676:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6678:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6678:CONSTANT:GPU with func:6681:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6787:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6787:CONSTANT:GPU with func:6788:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6789:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6789:CONSTANT:GPU with func:6790:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6791:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6791:CONSTANT:GPU with func:6792:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6805:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6805:CONSTANT:GPU with func:6810:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6806:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6806:CONSTANT:GPU with func:6811:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6807:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6807:CONSTANT:GPU with func:6812:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6808:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6808:CONSTANT:GPU with func:6813:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6809:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6809:CONSTANT:GPU with func:6814:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6831:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6831:CONSTANT:GPU with func:6832:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6833:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6833:CONSTANT:GPU with func:6834:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6835:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6835:CONSTANT:GPU with func:6836:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6980:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6980:CONSTANT:GPU with func:6981:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6995:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6995:CONSTANT:GPU with func:6996:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:6998:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:6998:CONSTANT:GPU with func:7001:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7007:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7007:CONSTANT:GPU with func:7008:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7022:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7022:CONSTANT:GPU with func:7023:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7025:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7025:CONSTANT:GPU with func:7028:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7134:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7134:CONSTANT:GPU with func:7135:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7136:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7136:CONSTANT:GPU with func:7137:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7138:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7138:CONSTANT:GPU with func:7139:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7152:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7152:CONSTANT:GPU with func:7157:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7153:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7153:CONSTANT:GPU with func:7158:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7154:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7154:CONSTANT:GPU with func:7159:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7155:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7155:CONSTANT:GPU with func:7160:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7156:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7156:CONSTANT:GPU with func:7161:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7178:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7178:CONSTANT:GPU with func:7179:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7180:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7180:CONSTANT:GPU with func:7181:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7182:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7182:CONSTANT:GPU with func:7183:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7189:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7189:CONSTANT:GPU with func:7190:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7191:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7191:CONSTANT:GPU with func:7192:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ConstShuffleFusion on func:7193:CONSTANT:GPU
[10/03/2023-06:13:33] [TRT] [V] ConstShuffleFusion: Fusing func:7193:CONSTANT:GPU with func:7194:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:192:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:192:SHUFFLE:GPU with func:200:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:209:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:209:SHUFFLE:GPU with func:215:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:222:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:222:SHUFFLE:GPU with func:275:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:229:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:229:SHUFFLE:GPU with func:238:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:251:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:251:SHUFFLE:GPU with func:260:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:222:SHUFFLE:GPU + func:275:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:222:SHUFFLE:GPU + func:275:SHUFFLE:GPU with func:281:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:229:SHUFFLE:GPU + func:238:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:229:SHUFFLE:GPU + func:238:SHUFFLE:GPU with func:244:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:251:SHUFFLE:GPU + func:260:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:251:SHUFFLE:GPU + func:260:SHUFFLE:GPU with func:266:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:402:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:402:SHUFFLE:GPU with func:413:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:402:SHUFFLE:GPU + func:413:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:402:SHUFFLE:GPU + func:413:SHUFFLE:GPU with func:421:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:430:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:430:SHUFFLE:GPU with func:436:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:546:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:546:SHUFFLE:GPU with func:554:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:926:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:926:SHUFFLE:GPU with func:934:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:563:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:563:SHUFFLE:GPU with func:569:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:943:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:943:SHUFFLE:GPU with func:949:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:991:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:991:SHUFFLE:GPU with func:1044:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:998:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:998:SHUFFLE:GPU with func:1007:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1020:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1020:SHUFFLE:GPU with func:1029:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:991:SHUFFLE:GPU + func:1044:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:991:SHUFFLE:GPU + func:1044:SHUFFLE:GPU with func:1050:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:998:SHUFFLE:GPU + func:1007:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:998:SHUFFLE:GPU + func:1007:SHUFFLE:GPU with func:1013:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1020:SHUFFLE:GPU + func:1029:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1020:SHUFFLE:GPU + func:1029:SHUFFLE:GPU with func:1035:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1141:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1141:SHUFFLE:GPU with func:1142:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1146:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1146:SHUFFLE:GPU with func:1147:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1198:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1198:SHUFFLE:GPU with func:1209:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1198:SHUFFLE:GPU + func:1209:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1198:SHUFFLE:GPU + func:1209:SHUFFLE:GPU with func:1217:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1542:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1542:SHUFFLE:GPU with func:1550:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1559:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1559:SHUFFLE:GPU with func:1565:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1572:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1572:SHUFFLE:GPU with func:1625:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1579:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1579:SHUFFLE:GPU with func:1588:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1601:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1601:SHUFFLE:GPU with func:1610:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1572:SHUFFLE:GPU + func:1625:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1572:SHUFFLE:GPU + func:1625:SHUFFLE:GPU with func:1631:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1579:SHUFFLE:GPU + func:1588:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1579:SHUFFLE:GPU + func:1588:SHUFFLE:GPU with func:1594:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1601:SHUFFLE:GPU + func:1610:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1601:SHUFFLE:GPU + func:1610:SHUFFLE:GPU with func:1616:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1752:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1752:SHUFFLE:GPU with func:1763:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1752:SHUFFLE:GPU + func:1763:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1752:SHUFFLE:GPU + func:1763:SHUFFLE:GPU with func:1771:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1780:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1780:SHUFFLE:GPU with func:1786:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1896:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1896:SHUFFLE:GPU with func:1904:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2276:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2276:SHUFFLE:GPU with func:2284:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:1913:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:1913:SHUFFLE:GPU with func:1919:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2293:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2293:SHUFFLE:GPU with func:2299:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2341:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2341:SHUFFLE:GPU with func:2394:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2348:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2348:SHUFFLE:GPU with func:2357:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2370:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2370:SHUFFLE:GPU with func:2379:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2341:SHUFFLE:GPU + func:2394:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2341:SHUFFLE:GPU + func:2394:SHUFFLE:GPU with func:2400:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2348:SHUFFLE:GPU + func:2357:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2348:SHUFFLE:GPU + func:2357:SHUFFLE:GPU with func:2363:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2370:SHUFFLE:GPU + func:2379:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2370:SHUFFLE:GPU + func:2379:SHUFFLE:GPU with func:2385:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2491:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2491:SHUFFLE:GPU with func:2492:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2496:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2496:SHUFFLE:GPU with func:2497:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2548:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2548:SHUFFLE:GPU with func:2559:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2548:SHUFFLE:GPU + func:2559:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2548:SHUFFLE:GPU + func:2559:SHUFFLE:GPU with func:2567:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2892:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2892:SHUFFLE:GPU with func:2900:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2909:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2909:SHUFFLE:GPU with func:2915:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2922:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2922:SHUFFLE:GPU with func:2975:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2929:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2929:SHUFFLE:GPU with func:2938:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2951:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2951:SHUFFLE:GPU with func:2960:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2922:SHUFFLE:GPU + func:2975:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2922:SHUFFLE:GPU + func:2975:SHUFFLE:GPU with func:2981:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2929:SHUFFLE:GPU + func:2938:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2929:SHUFFLE:GPU + func:2938:SHUFFLE:GPU with func:2944:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:2951:SHUFFLE:GPU + func:2960:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:2951:SHUFFLE:GPU + func:2960:SHUFFLE:GPU with func:2966:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3102:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3102:SHUFFLE:GPU with func:3113:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3102:SHUFFLE:GPU + func:3113:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3102:SHUFFLE:GPU + func:3113:SHUFFLE:GPU with func:3121:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3130:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3130:SHUFFLE:GPU with func:3136:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3246:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3246:SHUFFLE:GPU with func:3254:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3626:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3626:SHUFFLE:GPU with func:3634:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3263:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3263:SHUFFLE:GPU with func:3269:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3643:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3643:SHUFFLE:GPU with func:3649:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3691:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3691:SHUFFLE:GPU with func:3744:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3698:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3698:SHUFFLE:GPU with func:3707:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3720:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3720:SHUFFLE:GPU with func:3729:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3691:SHUFFLE:GPU + func:3744:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3691:SHUFFLE:GPU + func:3744:SHUFFLE:GPU with func:3750:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3698:SHUFFLE:GPU + func:3707:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3698:SHUFFLE:GPU + func:3707:SHUFFLE:GPU with func:3713:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3720:SHUFFLE:GPU + func:3729:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3720:SHUFFLE:GPU + func:3729:SHUFFLE:GPU with func:3735:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3841:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3841:SHUFFLE:GPU with func:3842:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3846:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3846:SHUFFLE:GPU with func:3847:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3898:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3898:SHUFFLE:GPU with func:3909:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:3898:SHUFFLE:GPU + func:3909:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:3898:SHUFFLE:GPU + func:3909:SHUFFLE:GPU with func:3917:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4042:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4042:SHUFFLE:GPU with func:4050:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4059:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4059:SHUFFLE:GPU with func:4065:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4072:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4072:SHUFFLE:GPU with func:4125:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4079:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4079:SHUFFLE:GPU with func:4088:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4101:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4101:SHUFFLE:GPU with func:4110:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4072:SHUFFLE:GPU + func:4125:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4072:SHUFFLE:GPU + func:4125:SHUFFLE:GPU with func:4131:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4079:SHUFFLE:GPU + func:4088:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4079:SHUFFLE:GPU + func:4088:SHUFFLE:GPU with func:4094:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4101:SHUFFLE:GPU + func:4110:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4101:SHUFFLE:GPU + func:4110:SHUFFLE:GPU with func:4116:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4252:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4252:SHUFFLE:GPU with func:4263:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4252:SHUFFLE:GPU + func:4263:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4252:SHUFFLE:GPU + func:4263:SHUFFLE:GPU with func:4271:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4280:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4280:SHUFFLE:GPU with func:4286:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4396:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4396:SHUFFLE:GPU with func:4404:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4776:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4776:SHUFFLE:GPU with func:4784:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4413:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4413:SHUFFLE:GPU with func:4419:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4793:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4793:SHUFFLE:GPU with func:4799:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4841:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4841:SHUFFLE:GPU with func:4894:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4848:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4848:SHUFFLE:GPU with func:4857:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4870:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4870:SHUFFLE:GPU with func:4879:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4841:SHUFFLE:GPU + func:4894:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4841:SHUFFLE:GPU + func:4894:SHUFFLE:GPU with func:4900:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4848:SHUFFLE:GPU + func:4857:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4848:SHUFFLE:GPU + func:4857:SHUFFLE:GPU with func:4863:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4870:SHUFFLE:GPU + func:4879:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4870:SHUFFLE:GPU + func:4879:SHUFFLE:GPU with func:4885:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4991:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4991:SHUFFLE:GPU with func:4992:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:4996:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:4996:SHUFFLE:GPU with func:4997:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5048:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5048:SHUFFLE:GPU with func:5059:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5048:SHUFFLE:GPU + func:5059:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5048:SHUFFLE:GPU + func:5059:SHUFFLE:GPU with func:5067:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5192:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5192:SHUFFLE:GPU with func:5200:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5209:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5209:SHUFFLE:GPU with func:5215:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5222:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5222:SHUFFLE:GPU with func:5275:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5229:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5229:SHUFFLE:GPU with func:5238:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5251:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5251:SHUFFLE:GPU with func:5260:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5222:SHUFFLE:GPU + func:5275:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5222:SHUFFLE:GPU + func:5275:SHUFFLE:GPU with func:5281:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5229:SHUFFLE:GPU + func:5238:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5229:SHUFFLE:GPU + func:5238:SHUFFLE:GPU with func:5244:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5251:SHUFFLE:GPU + func:5260:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5251:SHUFFLE:GPU + func:5260:SHUFFLE:GPU with func:5266:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5402:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5402:SHUFFLE:GPU with func:5413:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5402:SHUFFLE:GPU + func:5413:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5402:SHUFFLE:GPU + func:5413:SHUFFLE:GPU with func:5421:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5430:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5430:SHUFFLE:GPU with func:5436:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5546:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5546:SHUFFLE:GPU with func:5554:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5926:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5926:SHUFFLE:GPU with func:5934:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5563:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5563:SHUFFLE:GPU with func:5569:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5943:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5943:SHUFFLE:GPU with func:5949:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5991:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5991:SHUFFLE:GPU with func:6044:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5998:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5998:SHUFFLE:GPU with func:6007:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6020:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6020:SHUFFLE:GPU with func:6029:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5991:SHUFFLE:GPU + func:6044:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5991:SHUFFLE:GPU + func:6044:SHUFFLE:GPU with func:6050:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:5998:SHUFFLE:GPU + func:6007:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:5998:SHUFFLE:GPU + func:6007:SHUFFLE:GPU with func:6013:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6020:SHUFFLE:GPU + func:6029:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6020:SHUFFLE:GPU + func:6029:SHUFFLE:GPU with func:6035:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6141:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6141:SHUFFLE:GPU with func:6142:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6146:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6146:SHUFFLE:GPU with func:6147:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6198:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6198:SHUFFLE:GPU with func:6209:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6198:SHUFFLE:GPU + func:6209:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6198:SHUFFLE:GPU + func:6209:SHUFFLE:GPU with func:6217:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6542:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6542:SHUFFLE:GPU with func:6550:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6559:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6559:SHUFFLE:GPU with func:6565:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6572:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6572:SHUFFLE:GPU with func:6625:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6579:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6579:SHUFFLE:GPU with func:6588:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6601:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6601:SHUFFLE:GPU with func:6610:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6572:SHUFFLE:GPU + func:6625:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6572:SHUFFLE:GPU + func:6625:SHUFFLE:GPU with func:6631:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6579:SHUFFLE:GPU + func:6588:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6579:SHUFFLE:GPU + func:6588:SHUFFLE:GPU with func:6594:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6601:SHUFFLE:GPU + func:6610:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6601:SHUFFLE:GPU + func:6610:SHUFFLE:GPU with func:6616:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6752:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6752:SHUFFLE:GPU with func:6763:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6752:SHUFFLE:GPU + func:6763:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6752:SHUFFLE:GPU + func:6763:SHUFFLE:GPU with func:6771:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6780:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6780:SHUFFLE:GPU with func:6786:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6889:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6889:SHUFFLE:GPU with func:6897:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6906:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6906:SHUFFLE:GPU with func:6912:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6919:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6919:SHUFFLE:GPU with func:6972:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6926:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6926:SHUFFLE:GPU with func:6935:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6948:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6948:SHUFFLE:GPU with func:6957:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6919:SHUFFLE:GPU + func:6972:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6919:SHUFFLE:GPU + func:6972:SHUFFLE:GPU with func:6978:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6926:SHUFFLE:GPU + func:6935:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6926:SHUFFLE:GPU + func:6935:SHUFFLE:GPU with func:6941:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:6948:SHUFFLE:GPU + func:6957:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:6948:SHUFFLE:GPU + func:6957:SHUFFLE:GPU with func:6963:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:7099:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:7099:SHUFFLE:GPU with func:7110:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:7099:SHUFFLE:GPU + func:7110:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:7099:SHUFFLE:GPU + func:7110:SHUFFLE:GPU with func:7118:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleShuffleFusion on func:7127:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] ShuffleShuffleFusion: Fusing func:7127:SHUFFLE:GPU with func:7133:SHUFFLE:GPU
[10/03/2023-06:13:33] [TRT] [V] After Myelin optimization: 42 layers
[10/03/2023-06:13:33] [TRT] [V] Running: FCToConvTransform on func:7269:FULLY_CONNECTED:GPU
[10/03/2023-06:13:33] [TRT] [V] Convert layer type of func:7269:FULLY_CONNECTED:GPU from FULLY_CONNECTED to CONVOLUTION
[10/03/2023-06:13:33] [TRT] [V] Running: ShuffleErasure on shuffle_between_(Unnamed Layer* 8519) [Shuffle]output_and_func:7269:FULLY_CONNECTED:GPU
[10/03/2023-06:13:33] [TRT] [V] Removing shuffle_between(Unnamed Layer* 8519) [Shuffle]_output_and_func:7269:FULLY_CONNECTED:GPU
[10/03/2023-06:13:33] [TRT] [V] Applying ScaleNodes fusions.
[10/03/2023-06:13:33] [TRT] [V] After scale fusion: 42 layers
[10/03/2023-06:13:33] [TRT] [V] After dupe layer removal: 42 layers
[10/03/2023-06:13:33] [TRT] [V] After final dead-layer removal: 42 layers
[10/03/2023-06:13:33] [TRT] [V] After tensor merging: 42 layers
[10/03/2023-06:13:33] [TRT] [V] After vertical fusions: 42 layers
[10/03/2023-06:13:33] [TRT] [W] [RemoveDeadLayers] Input Tensor input_0 is unused or used only at compile-time, but is not being removed.
[10/03/2023-06:13:33] [TRT] [V] After slice removal: 42 layers
[10/03/2023-06:13:33] [TRT] [V] After concat removal: 42 layers
[10/03/2023-06:13:33] [TRT] [V] Trying to split Reshape and strided tensor
[10/03/2023-06:13:33] [TRT] [I] Graph optimization time: 0.491939 seconds.
[10/03/2023-06:13:33] [TRT] [V] Trying to load shared library libcublas.so.12
[10/03/2023-06:13:33] [TRT] [V] Loaded shared library libcublas.so.12
[10/03/2023-06:13:33] [TRT] [V] Using cublas as plugin tactic source
[10/03/2023-06:13:33] [TRT] [I] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +6, GPU +10, now: CPU 1216, GPU 394 (MiB)
[10/03/2023-06:13:33] [TRT] [V] Trying to load shared library libcudnn.so.8
[10/03/2023-06:13:33] [TRT] [V] Loaded shared library libcudnn.so.8
[10/03/2023-06:13:33] [TRT] [V] Using cuDNN as plugin tactic source
[10/03/2023-06:13:34] [TRT] [I] [MemUsageChange] Init cuDNN: CPU +773, GPU +10, now: CPU 1989, GPU 404 (MiB)
[10/03/2023-06:13:34] [TRT] [W] TensorRT was linked against cuDNN 8.9.0 but loaded cuDNN 8.5.0
[10/03/2023-06:13:34] [TRT] [I] BuilderFlag::kTF32 is set but hardware does not support TF32. Disabling TF32.
[10/03/2023-06:13:34] [TRT] [V] Building graph using backend strategy 2
[10/03/2023-06:13:34] [TRT] [I] Local timing cache in use. Profiling results in this builder pass will not be stored.
[10/03/2023-06:13:34] [TRT] [V] Constructing optimization profile number 0 [1/1].
[10/03/2023-06:13:34] [TRT] [V] Applying generic optimizations to the graph for inference.
[10/03/2023-06:13:34] [TRT] [V] Reserving memory for host IO tensors. Host: 0 bytes
[10/03/2023-06:13:34] [TRT] [V] =============== Computing costs for {ForeignNode[func:123:CONSTANT:GPU + func:135:SHUFFLE:GPU…func:153:SHUFFLE:GPU]}
[10/03/2023-06:13:34] [TRT] [V] *************** Autotuning format combination: → Float(393216,96,1), Float(393216,6144,96,1) ***************
[10/03/2023-06:13:34] [TRT] [V] --------------- Timing Runner: {ForeignNode[func:123:CONSTANT:GPU + func:135:SHUFFLE:GPU…func:153:SHUFFLE:GPU]} (Myelin[0x80000023])
[10/03/2023-06:13:34] [TRT] [V] (foreignNode) Set user’s cuda kernel library
[10/03/2023-06:13:34] [TRT] [V] (foreignNode) Pass fuse_conv_padding is currently skipped for dynamic shapes
[10/03/2023-06:13:34] [TRT] [V] (foreignNode) Pass pad_conv_channel is currently skipped for dynamic shapes
[10/03/2023-06:13:34] [TRT] [V] Tactic: 0x0000000000000000 Time: 0.010571
[10/03/2023-06:13:34] [TRT] [V] {ForeignNode[func:123:CONSTANT:GPU + func:135:SHUFFLE:GPU…func:153:SHUFFLE:GPU]} (Myelin[0x80000023]) profiling completed in 0.291668 seconds. Fastest Tactic: 0x0000000000000000 Time: 0.010571
[10/03/2023-06:13:34] [TRT] [V] >>>>>>>>>>>>>>> Chose Runner Type: Myelin Tactic: 0x0000000000000000
[10/03/2023-06:13:34] [TRT] [V] =============== Computing costs for func:176:CONSTANT:GPU
[10/03/2023-06:13:34] [TRT] [V] *************** Autotuning format combination: → Float(1) ***************
[10/03/2023-06:13:34] [TRT] [V] =============== Computing costs for func:175:SLICE:GPU
[10/03/2023-06:13:34] [TRT] [V] *************** Autotuning format combination: Float(393216,6144,96,1), Float(1) → Float(393216,6144,96,1) ***************
[10/03/2023-06:13:34] [TRT] [V] --------------- Timing Runner: func:175:SLICE:GPU (Slice[0x8000001b])
[10/03/2023-06:13:34] [TRT] [V] Tactic: 0x0000000000000000 Time: 0.00959634
[10/03/2023-06:13:34] [TRT] [V] func:175:SLICE:GPU (Slice[0x8000001b]) profiling completed in 0.0064971 seconds. Fastest Tactic: 0x0000000000000000 Time: 0.00959634
[10/03/2023-06:13:34] [TRT] [V] --------------- Timing Runner: func:175:SLICE:GPU (Padding[0x8000000c])
[10/03/2023-06:13:34] [TRT] [V] Padding has no valid tactics for this config, skipping
[10/03/2023-06:13:34] [TRT] [V] >>>>>>>>>>>>>>> Chose Runner Type: Slice Tactic: 0x0000000000000000
[10/03/2023-06:13:34] [TRT] [V] =============== Computing costs for {ForeignNode[func:445:IDENTITY:GPU…func:500:SHUFFLE:GPU]}
[10/03/2023-06:13:34] [TRT] [V] *************** Autotuning format combination: Float(393216,96,1), Float(393216,6144,96,1) → Float(393216,96,1), Float(393216,6144,96,1) ***************
[10/03/2023-06:13:34] [TRT] [V] --------------- Timing Runner: {ForeignNode[func:445:IDENTITY:GPU…func:500:SHUFFLE:GPU]} (Myelin[0x80000023])
[10/03/2023-06:13:35] [TRT] [V] (foreignNode) Set user’s cuda kernel library
[10/03/2023-06:13:35] [TRT] [V] (foreignNode) Pass fuse_conv_padding is currently skipped for dynamic shapes
[10/03/2023-06:13:35] [TRT] [V] (foreignNode) Pass pad_conv_channel is currently skipped for dynamic shapes
[10/03/2023-06:13:35] [TRT] [V] Tactic: 0x0000000000000000 Time: 0.226987
[10/03/2023-06:13:35] [TRT] [V] {ForeignNode[func:445:IDENTITY:GPU…func:500:SHUFFLE:GPU]} (Myelin[0x80000023]) profiling completed in 1.52472 seconds. Fastest Tactic: 0x0000000000000000 Time: 0.226987
[10/03/2023-06:13:35] [TRT] [V] >>>>>>>>>>>>>>> Chose Runner Type: Myelin Tactic: 0x0000000000000000
[10/03/2023-06:13:35] [TRT] [V] =============== Computing costs for func:523:CONSTANT:GPU
[10/03/2023-06:13:35] [TRT] [V] *************** Autotuning format combination: → Float(1) ***************
[10/03/2023-06:13:35] [TRT] [V] =============== Computing costs for func:522:SLICE:GPU
[10/03/2023-06:13:35] [TRT] [V] *************** Autotuning format combination: Float(393216,6144,96,1), Float(1) → Float(393216,6144,96,1) ***************
[10/03/2023-06:13:35] [TRT] [V] =============== Computing costs for {ForeignNode[(Unnamed Layer* 6938) [Identity]_output[Constant]…func:1503:SHUFFLE:GPU]}
[10/03/2023-06:13:35] [TRT] [V] *************** Autotuning format combination: Float(393216,96,1), Float(393216,6144,96,1) → Float(196608,192,1), Float(196608,6144,192,1) ***************
[10/03/2023-06:13:35] [TRT] [V] --------------- Timing Runner: {ForeignNode[(Unnamed Layer* 6938) [Identity]_output[Constant]…func:1503:SHUFFLE:GPU]} (Myelin[0x80000023])
[10/03/2023-06:13:36] [TRT] [V] Skipping tactic 0x0000000000000000 due to exception In op ‘func_1233_SLICE_GPU_decomptile(copy:replicate)’, expected shape [__mye9736={min=1, max=1},__mye9793={min=0, max=0},__mye9793={min=0, max=0},__mye9732={min=96, max=96}] but got [1,64,64,96]
[10/03/2023-06:13:36] [TRT] [V] {ForeignNode[(Unnamed Layer* 6938) [Identity]_output[Constant]…func:1503:SHUFFLE:GPU]} (Myelin[0x80000023]) profiling completed in 0.293799 seconds. Fastest Tactic: 0xd15ea5edd15ea5ed Time: inf
[10/03/2023-06:13:36] [TRT] [V] Deleting timing cache: 1 entries, served 1 hits since creation.
[10/03/2023-06:13:36] [TRT] [E] 10: Could not find any implementation for node {ForeignNode[(Unnamed Layer* 6938) [Identity]_output[Constant]…func:1503:SHUFFLE:GPU]}.
[10/03/2023-06:13:36] [TRT] [E] 10: [optimizer.cpp::computeCosts::3869] Error Code 10: Internal Error (Could not find any implementation for node {ForeignNode[(Unnamed Layer* 6938) [Identity]_output[Constant]…func:1503:SHUFFLE:GPU]}.)
