Forget about my login
I have a jetson nano developer kit, and i needed more memory space so i disable my desktop but i can’t log in because i forgot about my login. ( I know my password)
Is there a methode to re enable the desktop or recover my login
you mean you disabled GUI and forgot the username?
If you are using the SD card version, then I think you can read contents of the card with a host PC, and you should find username under /home.
Yes i mean username,
But when I insert my sd card into my PC, it says that I need to format it, so i can’t open it.
you will need a Linux PC or some software on Windows to read/write ext4 partitions.
