Hi
I forget the password of my nvidia developer kit and my pc is un able to read the card
The SD card is not encrypted. If you monitor “dmesg --follow
” on the host PC you are reading the SD card on, what do you see when you plug in the SD card?
I am using a program to read sd card now were can a cheak my password
There isn’t any kind of recommendation for “cracking” the password. You can reset a password with some effort, but the SD card itself is not encrypted. Basically, if you were to create a new SD card, and then use the l4t_create_default_user.sh
program on that SD card, then the password related files could be copied over the SD card (this is not entirely straightforward).
