FORTRAN 90 "where" statements
Can chevron syntax be used with FORTRAN 90 “where” statements, as it can with “do” statements? I’m guessing no, but I figured I would ask. Haven’t seen this documented anywhere, one way or the other. Thanks.
Hi cablesb,
Do you mean “Can I use the CUF Kernel directive for Where statements?”. Is so, then you are correct, the answer is no.
Best Regards,
Mat
Yep, that was it. Thanks.
