Using PGI Visual Fortran and Visual Studio 2010
Both projects are in the same solution.
Fortran static library has:
SUBROUTINE FOO(filename)
EXTERNAL init_www
CALL init_www_(filename)
END
C program has:
void init_www_(char *filename);
This is what the documentation in pgiug.pdf Chapter 12 pg 161 Example 12.3 says to do.
However, I can only get this to link if I use
CALL init_www(filename)
and not using
Is the documentation wrong in saying to use the CALL statement with an appended underscore for the C function?
