Fortran calling CUDA C (nvcc): Segfault on Fortran stop
I have a problem with Fortran → CUDA C interop. My kernels get executed fine, but whenever Fortran calls STOP I get a segfault. I tried manually calling a cudaDeviceReset - whenever this call gets called in any of my C functions, they immediately segfault upon entry, I don’t even get them to print something. cuda-memcheck as well as debugging with ddt will not lead to the segfault, so I’m dealing with a Heisenbug. Can you reproduce this?
Output
 test done
Warning: ieee_inexact is signaling
FORTRAN STOP
Segmentation fault
Fortran, compiled/linked with pgf90 15.3
module simple_weather
  use iso_c_binding
  implicit none
  interface
    subroutine diffuse_c(thermal_energy_updated, thermal_energy, nx, ny, nz) bind(C, name="diffuse_c")
      use iso_c_binding,only: c_int, c_double
      integer(c_int),value :: nx, ny, nz
      real(c_double), dimension(0:nx+1,0:ny+1,nz) :: thermal_energy_updated, thermal_energy
    end subroutine diffuse_c
  end interface
  contains
  subroutine testrun_cuda_kernels()
    real(8), allocatable, dimension(:,:,:) :: test_data, updated_test_data
    integer(4) :: nx, ny, nz
    nx = 1
    ny = 1
    nz = 3
    allocate(test_data(nz,0:nx+1,0:ny+1))
    allocate(updated_test_data(nz,0:nx+1,0:ny+1))
    test_data(:,:,:) = 0.0d0
    updated_test_data(:,:,:) = 0.0d0
    !$acc data copyin(test_data) copy(updated_test_data)
    !$acc host_data use_device(test_data,updated_test_data)
    call diffuse_c(updated_test_data, test_data, nx, ny, nz)
    !$acc end host_data
    !$acc end data
  end subroutine
end module
program main
  use simple_weather
  implicit none
  call testrun_cuda_kernels
  write(6,*) "test done"
  stop
end program main
CUDA C Code, compiled with nvcc 6.5.12
#include <stdio.h>
#include <stdlib.h>
#include <cuda.h>
#include <cuda_runtime.h>
#include <assert.h>
#define ACCESS_3D(pointer, i, j, k) pointer[(k) + (i) * nz + (j) * nz * (nx + 2)]
typedef const double * const __restrict__ IN;
typedef double * const __restrict__ OUT;
typedef const int SIZE;
extern "C" {
	void diffuse_c(OUT thermal_energy_updated, IN thermal_energy, SIZE nx, SIZE ny, SIZE nz);
#define gpuErrchk(ans) { gpuAssert((ans), __FILE__, __LINE__); }
inline void gpuAssert(cudaError_t code, char *file, int line, bool abort=true) {
	if (code != cudaSuccess) {
		fprintf(stderr,"GPUassert: %s %s %d\n", cudaGetErrorString(code), file, line);
		if (abort) { exit(code); }
__global__ void diffuse_kernel(
	OUT thermal_energy_updated, IN thermal_energy, SIZE nx, SIZE ny, SIZE nz, const double scale_0, const double scale_rest
	int i = blockIdx.x*blockDim.x + threadIdx.x + 1;
	int j = blockIdx.y*blockDim.y + threadIdx.y + 1;
	if (i > nx || j > ny) {
		return;
	for (int k = 1; k < nz-1; k++) {
		double updated = scale_0 * ACCESS_3D(thermal_energy,i,j,k) + scale_rest * (
			ACCESS_3D(thermal_energy,i-1,j,k) + ACCESS_3D(thermal_energy,i+1,j,k) +
			ACCESS_3D(thermal_energy,i,j-1,k) + ACCESS_3D(thermal_energy,i,j+1,k) +
			ACCESS_3D(thermal_energy,i,j,k-1) + ACCESS_3D(thermal_energy,i,j,k+1)
		ACCESS_3D(thermal_energy_updated,i,j,k) = updated;
void diffuse_c(OUT thermal_energy_updated, IN thermal_energy, SIZE nx, SIZE ny, SIZE nz) {
	//setup
    int block_size_x = 32, block_size_y = 16;
	dim3 threads(block_size_x, block_size_y, 1);
	double diffusion_velocity = 0.13;
	//kernel launch for the inner region
	dim3 grid_ij_inner(max(nx/block_size_x,1), max(ny/block_size_y,1), 1);
	diffuse_kernel<<<grid_ij_inner, threads>>>(
		thermal_energy_updated, thermal_energy, nx, ny, nz, 1.0 - 6.0 * diffusion_velocity, diffusion_velocity
	gpuErrchk(cudaDeviceSynchronize());
       //cudaDeviceReset(); //THIS LEADS TO SEGFAULT EVEN *BEFORE* CALLING ANY OF THE ABOVE CODE.
I think you were missing a “contains” statement in your Fortran module.
No, I do not get a seg fault. What options do you use in building and linking?
Thanks brentl and sorry for the contains - it got lost when I created the snippet, I just corrected it. Attached you find my build commands. May I ask what compiler versions you’re testing with? (if it’s just my version I’ll just try and move on to another one).
pgf90 -g -Mcuda=cc3x -ta=nvidia,cc3x -Mbounds -Mchkptr -Minfo=accel,inline -Mneginfo -Minform=inform -I/usr/local/include  -c simple_weather.f90 -o simple_weather.o
nvcc -G -arch compute_30  -c kernels.cu -o kernels.o
pgf90 -o simple_weather.out simple_weather.o kernels.o -Mcuda=cc3x -ta=nvidia,cc3x,time -L/usr/local/lib -L/opt/cuda-6.5/lib64 -lcudart -lstdc++ -L./ >/dev/null
edit: When doing a production build without -g / -G / chkptr / bounds flags, but with -O3, the segfault is still there.
edit2: simplified my build a bit (without building / linking a .a library) - same result.
Interesting. It is coming from the time option on the -ta flag. I don’t see time documented anymore, but it certainly causes this failure. Let me check on that.
wow, you’re right! So, is “time” deprecated now? Has it been replaced by something else? I’d be OK if the feature is gone (I can measure myself / use nvprof), it would just be good to know whether the deprecation has been documented somewhere.
