The 17.4-0 compiler seems to contradict the Fortran 2008 and probably the Fortran 2003 standards in the way it manipulates binary and hexadecimal constants in a corner case.
The offending situation happens (at least) when:
- the boz-literal-constant is a binary or hexadecimal constant, and
- the boz constant is the first argument of the INT intrinsic, and
- the second argument of the INT intrinsic is kind=selected_int_kind(18) or equivalent (so that, given the sizes of integers supported by the PGI compiler, the result is a 64-bit integer), and
- the written boz constant specifies 32 bits (that is, is composed of 8 hexadecimal digits or 32 binary digits), and
- the most significant bit of the boz constant is a one.
Under these circumstances, the result value of the INT function according to the 2003 standard (section 13.7.53) should follow the following rule
“If A is a boz-literal-constant, it is treated as if it were an int-literal-constant with a kind-param that specifies the representation method with the largest decimal exponent range supported by the processor.”
The 2008 standard (section 13.3.3) is more clear:
“When a boz-literal-constant is the argument A of the intrinsic function INT or REAL, if the length of the sequence of bits specified by A is less than the size in bits of a scalar variable of the same type and kind type parameter as the result, the boz-literal-constant is treated as if it were extended to the length equal to the size in bits of the result by padding on the left with zero bits […],”
According to this, the output one would expect from
program minbozint
implicit none
integer, parameter :: LONG = selected_int_kind(18)
integer(kind=LONG) :: Vz, Vo, Vb, LONG_huge
LONG_huge = huge(LONG_huge)
! Hexadecimal
!76543210
Vz = int(z'80000000', kind=LONG)
! Octal
!10 0
!09876543210
Vo = int(o'20000000000', kind=LONG)
! Binary
!332 21 10 0
!10987654321098765432109876543210
Vb = int(b'10000000000000000000000000000000', kind=LONG)
!!!!! Write everything !!!!!
write(*,'(a, 28x, a)') "Position", "76543210"
write(*,'(a,i20,1x,z16)') "Vz = ", Vz, Vz
write(*,'(a,i20,1x,z16)') "Vo = ", Vo, Vo
write(*,'(a,i20,1x,z16)') "Vb = ", Vb, Vb
write(*,'(a,i20,1x,z16)') "huge = ", LONG_huge, LONG_huge
end program minbozint
should be (for a compiler that supports 64-bit integers)
Position 76543210
Vz = 2147483648 80000000
Vo = 2147483648 80000000
Vb = 2147483648 80000000
huge = 9223372036854775807 7FFFFFFFFFFFFFFF
However, the output the PGI compiled-code produces is
Position 76543210
Vz = -2147483648 FFFFFFFF80000000
Vb = -2147483648 FFFFFFFF80000000
If this is a compiler bug, could you please fix it?
Mind that I have not fully investigated the conditions a-e above: e.g., I cannot make sense of the results of REAL(, kind=selected_real_kind(15,300)).
