Is it possible to call subroutines with explicit array arguments?
program test
implicit none
real(8), dimension(100) :: a, b
integer :: i
do i=1,100,1
a(i) = real(i,8)
b(i) = a(i)**2
end do
!$acc data copy(a(:),b(:))
!$acc parallel loop
do i=1,100,1
call sub(a(i),b(i))
end do
!$acc end data
write(*,*) sum(b)
contains
pure subroutine sub(a,b)
use mdl
!$acc routine seq
implicit none
real(8), intent(in) :: a
real(8), intent(inout) :: b
real(8), dimension(1) :: f1
real(8), dimension(2) :: f2
! works fine
!f1 = [1._8]
!f2 = [1._8,1._8]
!call mdl_sub_1(f1,a,b)
!call mdl_sub_2(f2,a,b)
! problem with explicit array argument
call mdl_sub_1([1._8],a,b)
call mdl_sub_2([1._8,1._8],a,b)
end subroutine sub
end program test
module mdl
implicit none
contains
pure subroutine mdl_sub_1(factor,a,b)
!$acc routine seq
real(8), intent(in), dimension(1) :: factor
b = factor(1)*a + b
end subroutine mdl_sub_1
pure subroutine mdl_sub_2(factor,a,b)
!$acc routine seq
real(8), intent(in), dimension(2) :: factor
b = factor(1)*a + factor(2)*b
end subroutine mdl_sub_2
end module mdl
mdl.f90:
pro.f90:
PGF90-S-0155-Compiler failed to translate accelerator region (see -Minfo messages): No device symbol for address reference (pro.f90: 1)
PGF90-F-0704-Compilation aborted due to previous errors. (pro.f90)
PGF90/x86-64 Linux 19.4-0: compilation aborted
