PGI Fortran Reference page 126 (chapeter 5) says that
If the specified unit is a printer then the first character of the record is used to
control the vertical spacing as shown in the following table: …
I tried to use this with ‘+’ and ‘1’ but they dont seem working. It just print a line preceeded by a charcter ‘+’ or ‘1’ insgtead of formfeed or overwriting the line. How do I use this feature? Could you give me a sample code (and compiler flag if needed). I have old code that seems to use this feature, and ideally want to use code without much modification.
What I tried was
% pgf90 -V
pgf90 6.0-8 32-bit target on x86 Linux
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2005, STMicroelectronics, Inc. All Rights Reserved.
% cat test.f90
program test
write(*,'("+","hello")')
print'("+","hello")'
100 format("+","hello")
print 100
print 100
print 100
end program
% pgf90 test.f90
% ./a.out
+hello
+hello
+hello
+hello
+hello
+hello
+hello
+hello
+hello
Similar results when I used ‘1’.[/code]
