The following code shows different upper and lower bounds when passing a slice of an array to a subroutine with polymorphic type for that argument. The modified bounds are only present inside the select type construct
program select_type_bug
implicit none
integer :: values(2)
values = 10
call foo(values)
call foo(values(:1))
call foo(values(:2))
contains
subroutine foo(attr)
class(*), intent(in) :: attr(:)
write(*,*) 'outside', SIZE(attr), LBOUND(attr),UBOUND(attr)
select type(attr)
type is (integer)
write(*,*) 'inside ', SIZE(attr), LBOUND(attr),UBOUND(attr)
end select
end subroutine
end program
Produces the output
outside 2 1 2
inside 2 1 2
outside 1 1 1
inside 1 0 0
outside 2 1 2
inside 2 0 1
Best,
Henning Janßen
