Fortran type bound function returning short integer fails
we are trying to compile some Fortran libraries and we encounter some errors. We extracted the following minimal reproducing example which fails using nvfortran 20.7.
program test
type :: a_object
contains
procedure :: to_integer_I2P
endtype a_object
integer, parameter :: I2P=selected_int_kind(4)
type(a_object) :: object
print*, object%to_integer_I2P()
contains
function to_integer_I2P(self) result(n) ! it does not work
class(a_object) :: self
integer(I2P) :: n
endfunction to_integer_I2P
endprogram test
Francesco
The code doesn’t seem valid (at least it errors with ifort and gfortran). Is the issue that nvfortran isn’t catching the errors as well? I can submit a problem report, but given this is from a larger, presumably correct, code, I want to make sure our engineers are fixing the correct issue.
    % ifort --version
    ifort (IFORT) 19.1.1.217 20200306
    Copyright (C) 1985-2020 Intel Corporation.  All rights reserved.
     % ifort test.f90
    test.f90(4): error #8258: The procedure name in a type-bound procedure declaration should be the name of an accessible module procedure or an external procedure that has an explicit interface.   [TO_INTEGER_I2P]
    test.f90(10): error #8607: The procedure interface for the type bound procedure is not yet available.   [TO_INTEGER_I2P]
    test.f90(10): error #8497: Illegal use of a procedure name in an expression, possibly a function call missing parenthesis.   [TO_INTEGER_I2P]
    test.f90(12): warning #6178: The return value of this FUNCTION has not been defined.   [N]
    compilation aborted for test.f90 (code 1)
    % gfortran --version
    GNU Fortran (GCC) 9.2.0
    Copyright (C) 2019 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    % gfortran test.f90
    test.f90:4:9:
        4 | procedure :: to_integer_I2P
          |         1
    Error: ‘to_integer_i2p’ must be a module procedure or an external procedure with an explicit interface at (1)
    test.f90:10:7:
   10 | print*, object%to_integer_I2P()
  |       1
Error: ‘to_integer_i2p’ at (1) should be a FUNCTION
Sorry, we reduced the code too much. However, including explicit interfaces using a module:
module test
type :: a_object
contains
endtype a_object
! integer, parameter :: I2P=selected_int_kind(9) ! this works
integer, parameter :: I2P=selected_int_kind(4) ! this does not work
contains
integer(I2P) :: n
endmodule test
we still have the following error using nvfortran x86 compiler (ppc64 nvfortran compiler works, gfortran works):
/opt/nvidia/hpc_sdk/Linux_x86_64/20.7/compilers/share/llvm/bin/llc: error: /opt/nvidia/hpc_sdk/Linux_x86_64/20.7/compilers/share/llvm/bin/llc: /tmp/nvfortranCeXdu9xI6Tl-.ll:8:67: error: invalid forward reference to function ‘test_to_integer_i2p_’ with wrong type: expected ‘i32 (i64*, i64*)’ but was 'i32 ()
@test$a_object$$td$vft = global [1 x i8*] [i8* bitcast(i32 ()* @test_to_integer_i2p_ to i8*)]
Francesco
Thanks Francesco, we appreciate that. I added a new problem report (TPR#29177) for the LLVM code generation issue. I also went ahead and added TPR#29118 to see if we can catch the errors in the earlier code as well.
-Mat
This issue was fixed in our 20.11 release.
TPR#29118 was fixed in 22.3 and the compiler now catches the error in the initial incorrect example:
% nvfortran test.f90 -V22.3
NVFORTRAN-F-1249-Type-bound procedure to_integer_i2p must be a module procedure or external procedure with an explicit interface. (test.f90: 10)
NVFORTRAN/x86-64 Linux 22.3-0: compilation aborted
