This does not affect driver functionality, it affects only the creation of debugfs file with registers images. The return value check from “ret = debugfs_create_file(…)” causes an error return when it is successful and vice versa… Less common - if debugfs_create_dir returns an error code instead of pointer it will interpreted as success.
Fixes below:
diff --git a/drivers/video/ds90ub947-q1.c b/drivers/video/ds90ub947-q1.c
index d2270e3..e56ad3a 100644
--- a/drivers/video/ds90ub947-q1.c
+++ b/drivers/video/ds90ub947-q1.c
@@ -212,12 +212,12 @@ static void ds90ub947_panel_create_debugfs(struct ds90ub947_data *data)
struct dentry *ret;
data->debugdir = debugfs_create_dir(DEV_NAME, NULL);
- if (!data->debugdir)
+ if (IS_ERR_OR_NULL(data->debugdir))
goto err;
ret = debugfs_create_file("init_regs", S_IRUGO, data->debugdir, data,
&init_regs_fops);
- if (ret)
+ if (IS_ERR_OR_NULL(ret))
goto err;
return;
Many thanks for this sharing!
Found another minor bug (or is it a feature?): if the device tree for a node using this driver does not have an “init-regs” value the parsing is ended and does not parse anything else (except the “ti,enable-gpio” entry which is parsed before “init-regs”).
index e56ad3a..91c723a 100644
@@ -256,24 +256,24 @@ static int of_ds90ub947_parse_pdata(struct i2c_client *client,
of_property_for_each_u32(np, "init-regs", prop, p, u)
count++;
- if (!count)
- return 0;
+ if (count) {
- if ((count % 3) != 0) {
- dev_err(&data->client->dev, "invalid \"init-regs\" data\n");
- return -EINVAL;
+ if ((count % 3) != 0) {
+ dev_err(&data->client->dev, "invalid \"init-regs\" data\n");
+ return -EINVAL;
- init_regs = devm_kzalloc(&client->dev, count * sizeof(u), GFP_KERNEL);
- if (!init_regs) {
- dev_err(&client->dev, "Failed to allocate init_regs\n");
- return -ENOMEM;
+ init_regs = devm_kzalloc(&client->dev, count * sizeof(u), GFP_KERNEL);
+ if (!init_regs) {
+ dev_err(&client->dev, "Failed to allocate init_regs\n");
+ return -ENOMEM;
- of_property_for_each_u32(np, "init-regs", prop, p, u)
- init_regs[i++] = u & 0xff;
+ of_property_for_each_u32(np, "init-regs", prop, p, u)
+ init_regs[i++] = u & 0xff;
- data->init_regs = init_regs;
+ data->init_regs = init_regs;
data->n_init_regs = count;
if (!of_property_read_u32(np, "ti,enable-bchnl-i2c", &temp))
