Foundation object exists already. : fine tune reward weights by running launch_hydra iteretively
I am trying to fine tune my reward weights by calling the launch_hydra function in the training script many time for different parameters. However after the first iteration I get this error. Do after max epochs have been reached and the launch_hydra function has been called again.
/buildAgent/work/99bede84aa0a52c2/source/foundation/FdFoundation.cpp invalid operation : Foundation object exists already. Only one instance per process can be created.
How can. I manually delete the foundation object as it seems to not be done automatically.
Have you fixed this problem? I’m facing similar problem now. Thank you for you reply
Hello, I encountered the same problem. Later I found out that I accidentally ran
gym.create_sim
twice and deleted one of them and solved the problem.
Have you solved the problem? I want to adjust my environment, so I need to creat a new one.
