[FoundationposeSampling] No valid value in mask when launching quickstart of isaac_ros_foundationpose 3.2
I want to use foundationpose for object tracking and pose estimation. To understand the way to use foundationpose, I tried quickstart of isaac_ros_foundation.
I successfully completed “Download Quickstart Assets” and “Build (installed binary packages)”. Next, I did “Run Launch File” with rosbag. and “Visualize Results”. And then, I could not see detected objects on View panel like following screenshot.
I checked a terminal for isaac_ros_examples.launch.py. I found the ERROR “ERROR ./gxf/foundationpose/foundationpose_sampling.cpp@310: [FoundationposeSampling] No valid value in mask.” Output of the terminal can be seen from this log file.
foundationpose_log.txt (101.5 KB)
If someone knows the way to cope with this trouble, could you please let me know it? I appreciate any help.
Host computer: Ubuntu 24.04
Container: Ubuntu 22.04 + ROS2 humble
  • this container is built from run_dev.sh. I set CONFIG_IMAGE_KEY=ros2_humble.realsense. And, in build-librealsense.sh, I changed USE_CUDA to false manually because if USE_CUDA is true, RGB frame from RealSense was not shown on Rviz2. But, in case of the trouble above, no realsense device was connected.
I fixed this problem. Just update CUDA version to 12.6.
According to ISAAC ROS 3.2 release note, 3.2 requires CUDA 12.6.
