Fpenet custom landmarks export error
• Network Type fpenet
• TLT Version 4.0
• Training spec file experiment_spec.yaml (2.3 KB)
Using custom landmarks to train fpenet works fine. However, when deploying, exporting the etlt model fails and reports the following error:
2023-03-28 08:43:07,990 [INFO] root: Registry: ['nvcr.io']
2023-03-28 08:43:08,024 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
2023-03-28 08:43:08,184 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/nxin/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
2023-03-28 00:43:09.138542: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
  RequestsDependencyWarning)
/usr/local/lib/python3.6/dist-packages/numba/cuda/envvars.py:17: NumbaWarning:
Environment variables with the 'NUMBAPRO' prefix are deprecated and consequently ignored, found use of NUMBAPRO_NVVM=/usr/local/cuda/nvvm/lib64/libnvvm.so.
For more information about alternatives visit: ('http://numba.pydata.org/numba-doc/latest/cuda/overview.html', '#cudatoolkit-lookup')
  warnings.warn(errors.NumbaWarning(msg))
Environment variables with the 'NUMBAPRO' prefix are deprecated and consequently ignored, found use of NUMBAPRO_LIBDEVICE=/usr/local/cuda/nvvm/libdevice/.
2023-03-28 00:43:14,454 [WARNING] __main__: Please verify the input dimension and input name before using this code!
2023-03-28 00:43:14,454 [WARNING] driveix.fpenet.exporter.fpenet_exporter: Using default normalization params!
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2023-03-28 00:43:14,454 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2023-03-28 00:43:14,527 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2023-03-28 00:43:14,537 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2023-03-28 00:43:14,546 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2023-03-28 00:43:14,727 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:181: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2023-03-28 00:43:14,727 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:181: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:186: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2023-03-28 00:43:14,727 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:186: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2023-03-28 00:43:15,728 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2023-03-28 00:43:15,728 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2023-03-28 00:43:16,260 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
  File "</usr/local/lib/python3.6/dist-packages/driveix/fpenet/scripts/export.py>", line 3, in <module>
  File "<frozen driveix.fpenet.scripts.export>", line 251, in <module>
  File "<frozen driveix.fpenet.scripts.export>", line 247, in main
  File "<frozen driveix.fpenet.scripts.export>", line 239, in run_export
  File "<frozen driveix.fpenet.exporter.fpenet_exporter>", line 199, in export
  File "<frozen driveix.fpenet.exporter.fpenet_exporter>", line 124, in export_to_etlt
  File "<frozen driveix.common.utilities.tlt_utils>", line 461, in change_model_batch_size
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py", line 492, in model_from_json
    return deserialize(config, custom_objects=custom_objects)
  File "/usr/local/lib/python3.6/dist-packages/keras/layers/__init__.py", line 55, in deserialize
    printable_module_name='layer')
  File "/usr/local/lib/python3.6/dist-packages/keras/utils/generic_utils.py", line 145, in deserialize_keras_object
    list(custom_objects.items())))
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/network.py", line 1032, in from_config
    process_node(layer, node_data)
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/network.py", line 991, in process_node
    layer(unpack_singleton(input_tensors), **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/base_layer.py", line 431, in __call__
    self.build(unpack_singleton(input_shapes))
  File "<frozen driveix.fpenet.models.custom.softargmax>", line 78, in build
AssertionError
Telemetry data couldn't be sent, but the command ran successfully.
[WARNING]: <urlopen error [Errno -2] Name or service not known>
Execution status: FAIL
2023-03-28 08:43:17,727 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Export command:
!tao fpenet export -m $USER_EXPERIMENT_DIR/models/exp1/model.step-89600.tlt \
                   -k $KEY \
                   --backend onnx
I conducted training and deployment experiments on the face dataset provided in the example, and everything works fine. Is there any difference in deployment for custom landmarks?
I would like to know how to solve this deployment issue.
When I adjust the dimensions of the training data to the default (1, 80, 80), the training and exporting of custom keypoints are normal.
Referring to my previous question about modifying the number of channels How fpenet is trained in three channels? - Intelligent Video Analytics / TAO Toolkit - NVIDIA Developer Forums, does this mean that there might be errors in the support for custom training dimensions in FPEnet? Only the default dimensions can work properly?
Can you refer to Facial Landmarks Estimation - NVIDIA Docs and add --input_dims ?
tao fpenet export -m <Trained TAO Model Path> -k <Encode Key> -o <Output file .etlt>
  • --input_dims: Input dims in channels first(CHW) or channels last (HWC) format as comma separated integer values. Default 1,80,80.
