FPENET dimensions export error
• Network Type: FPENET
• TAO Version: 4.0.1-tf1.15.5 / 5.0.0-tf1.15.5
• Training spec: experiment_spec.yaml (2.8 KB)
Hi, I am finetuning the pretrained FPENET model from NGC with a custom dataset of 10 keypoints with input dimensions of 160x160. The training is working fine, but when I try to export the model to a .etlt file, I encounter an error. It is similar to Fpenet custom landmarks export error. - but even with adding the --input_dims flag as mentioned in the thread, it does not work.
When I run:
fpenet export  -m $USER_EXPERIMENT_DIR/models/exp1/model.tlt -k $KEY --input_dims 1,160,160
I am getting the following output:
  File "</usr/local/lib/python3.6/dist-packages/driveix/fpenet/scripts/export.py>", line 3, in <module>
  File "<frozen driveix.fpenet.scripts.export>", line 251, in <module>
  File "<frozen driveix.fpenet.scripts.export>", line 247, in main
  File "<frozen driveix.fpenet.scripts.export>", line 239, in run_export
  File "<frozen driveix.fpenet.exporter.fpenet_exporter>", line 199, in export
  File "<frozen driveix.fpenet.exporter.fpenet_exporter>", line 124, in export_to_etlt
  File "<frozen driveix.common.utilities.tlt_utils>", line 461, in change_model_batch_size
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py", line 492, in model_from_json
    return deserialize(config, custom_objects=custom_objects)
  File "/usr/local/lib/python3.6/dist-packages/keras/layers/__init__.py", line 55, in deserialize
    printable_module_name='layer')
  File "/usr/local/lib/python3.6/dist-packages/keras/utils/generic_utils.py", line 145, in deserialize_keras_object
    list(custom_objects.items())))
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/network.py", line 1032, in from_config
    process_node(layer, node_data)
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/network.py", line 991, in process_node
    layer(unpack_singleton(input_tensors), **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/base_layer.py", line 431, in __call__
    self.build(unpack_singleton(input_shapes))
  File "<frozen driveix.fpenet.models.custom.softargmax>", line 78, in build
AssertionError
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
  RequestsDependencyWarning)
Telemetry data couldn't be sent, but the command ran successfully.
[WARNING]: __init__() missing 4 required positional arguments: 'code', 'msg', 'hdrs', and 'fp'
Execution status: FAIL
When I train and export the model with 80x80, also the export is working fine.
I also tried training and exporting the network with the 5.0.0-tf1.15.5 container: There I get a similar error message when exporting the 160x160 network:
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/fpenet/scripts/export.py", line 318, in <module>
    main()
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/fpenet/scripts/export.py", line 314, in main
    raise e
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/fpenet/scripts/export.py", line 298, in main
    run_export(args)
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/fpenet/scripts/export.py", line 275, in run_export
    exporter.export(input_dims,
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/fpenet/exporter/fpenet_exporter.py", line 215, in export
    _, in_tensor_name, out_tensor_names = self.generate_exported_model(
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/fpenet/exporter/fpenet_exporter.py", line 140, in generate_exported_model
    new_model = change_model_batch_size(model,
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utilities/tlt_utils.py", line 474, in change_model_batch_size
    new_model = keras.models.model_from_json(model.to_json(), custom_objects=custom_objects)
  File "/usr/local/lib/python3.8/dist-packages/keras/engine/saving.py", line 492, in model_from_json
  File "/usr/local/lib/python3.8/dist-packages/keras/layers/__init__.py", line 52, in deserialize
    return deserialize_keras_object(config,
  File "/usr/local/lib/python3.8/dist-packages/keras/utils/generic_utils.py", line 142, in deserialize_keras_object
    return cls.from_config(
  File "/usr/local/lib/python3.8/dist-packages/keras/engine/network.py", line 1032, in from_config
  File "/usr/local/lib/python3.8/dist-packages/keras/engine/network.py", line 991, in process_node
  File "/usr/local/lib/python3.8/dist-packages/keras/engine/base_layer.py", line 431, in __call__
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/fpenet/models/custom/softargmax.py", line 92, in build
    assert tuple(self._input_shape[1:]) == tuple(input_shape[1:])
AssertionError
I also printed the assertion args during the export from
“/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/fpenet/models/custom/softargmax.py”,
90	        print(tuple(input_shape[:]))
91	        print(tuple(self._input_shape[:]))
92	        assert tuple(self._input_shape[1:]) == tuple(input_shape[1:])
The output is
(32, 10, 160, 160)
(32, 10, 160, 160)
(None, 10, 80, 80)
(32, 10, 160, 160)
    main()
It seems during the first call, the assertion is True, and the second time it is false.
I hope you can provide me some workaround for exporting the network with a larger size than 80x80.
Could you modify https://github.com/NVIDIA/tao_tensorflow1_backend/blob/d73dcfcc2191a91ae80616b7ffed7f55ac6692ef/nvidia_tao_tf1/cv/fpenet/exporter/fpenet_exporter.py#L139 and replace it in the docker?
Login the docker and find the fpenet_exporter.py.
Then replace it with the modified version.
Suggest to backup the original fpenet_exporter.py.
Your proposed modification fixed the issue.
