• Network Type fpenet
• TLT Version 3.22.05 cv_samples_v1.4.0
• Training spec file
experiment_spec.yaml (2.3 KB)
• How to reproduce the issue ?
I trained successfully with the default settings. Then I modified dataset_config.yaml parameter bbox_enlarge_ratio1.0 to 1.2, report an error.
How fpenet calculates bbox?
If I want to scale the bbox up or down, what training parameters should I focus on?
INFO 2022-10-31 07:28:18,040| tensorflow: Graph was finalized.
INFO 2022-10-31 07:28:19,475| tensorflow: Running local_init_op.
INFO 2022-10-31 07:28:20,933| tensorflow: Done running local_init_op.
INFO 2022-10-31 07:28:31,333| tensorflow: Saving checkpoints for step-0.
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1365, in _do_call
return fn(*args)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1350, in _run_fn
target_list, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1443, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.InvalidArgumentError: 2 root error(s) found.
(0) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_38447}} assertion failed: [height must be >= target + offset.]
[[{{node crop_to_bounding_box_5/Assert_5/Assert}}]]
[[IteratorGetNext_1]]
[[RegexFullMatch_19/_1711]]
(1) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_38447}} assertion failed: [height must be >= target + offset.]
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/fpenet/scripts/train.py", line 141, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/fpenet/scripts/train.py", line 137, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/fpenet/trainers/fpenet_trainer.py", line 286, in train
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/fpenet/trainers/fpenet_trainer.py", line 332, in run_training_loop
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 754, in run
run_metadata=run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1360, in run
raise six.reraise(*original_exc_info)
File "/usr/local/lib/python3.6/dist-packages/six.py", line 696, in reraise
raise value
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1345, in run
return self._sess.run(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1418, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1176, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 956, in run
run_metadata_ptr)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1180, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1359, in _do_run
run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1384, in _do_call
raise type(e)(node_def, op, message)
(0) Invalid argument: assertion failed: [height must be >= target + offset.]
(1) Invalid argument: assertion failed: [height must be >= target + offset.]
File "/usr/local/bin/fpenet", line 8, in <module>
sys.exit(main())
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/fpenet/entrypoint/fpenet.py", line 12, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/entrypoint/entrypoint.py", line 300, in launch_job
AssertionError: Process run failed.
