We want to know if communication between a FPGA module ( AMD Zynq UltraScale+ MPSoC ) and Jetson Orin NX is supported over PCIe lanes.
Please confirm.
Thanks,
Nagesh R
Please confirm.
Thanks,
Nagesh R
Suggest to discuss with vendor to know if they have experience to do the porting on Jetson platform.
Ok. thanks for the updates.
So you mean from Jetson side there is no compatibility issue for AMD FPGA ??
We don’t have any validation with FPGA, just general PCIe functions.
There are many customers who have completed the integration by themselves with the help from vendors, and file PCIe related issue to us to resolve.
Thanks for the updates.
Hi @nagesh_accord,
From RidgeRun’s side, we have experience implementing FPGA communication solutions with NVIDIA Jetson platforms. For example, our FPGA Image Signal Processor (FPGA-ISP) framework supports FPGA-based image processing pipelines integrated with Jetson systems and can be adapted for different FPGA platforms and interfaces, including PCIe-based solutions, you can find more details at the following link:
As NVIDIA mentioned, Jetson Orin NX provides standard PCIe functionality, and FPGA integration is generally feasible as long as the FPGA endpoint and corresponding drivers/software stack are properly implemented.
Regards,
Pedro
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Hi Pedro,
Thanks for the updates. What I heard was customer is going to do the FPGA coding/implementation part. We are only providing the hardware.
Hence doing device treee changes ( from software side ) and proper hardware connections between Jetson and AMD FPGA over PCIe should be fine I suppose to make it work.
even AMD confirmed that FPGA as EP device should work.
In case of any support related to driver or other issues during implementation we shall contact you.
Thanks,
Nagesh R
