FPGA mipi to xavier nx issuse in Jetpack 5.1.4
In our custom board, we successfully get FPAG mipi to jetson works in Jetpack 4.6.3(r3273).
But when we upgrade Jetpack to 5.1.4(r3560) with the same driver and device tree( device tree changed because some node name changed), we can not get the stream data.
Here is the dmesg info and trace log
I know there is a lot change in csi/vi driver between two version. But in our other board using lt6911, there is no problem with data transmit.
I wonder how to fix this. Below is the dts file in different version
r3273_device_tree.txt (10.8 KB)
r3560_device_tree.txt (11.4 KB)
hello 854053437,
please refer to Camera Driver Porting for driver migration.
Hi, Jerry
the old driver is based on ov5693.c and I check the new driver which is nv_5693.c. There is only adding err judgment and in my driver didn’t use it at all
Hi, Jerry
I changed the driver and not use nvidia v4l2 format. Now we can get the data from fpga.
There is no err info from gstreamer
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY,width=3840,height=2160,framerate=60/1 ! videoconvert ! ximagesink sync=false
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstXImageSink:ximagesink0: Output window was closed
Additional debug info:
ximagesink.c(696): gst_x_image_sink_handle_xevents (): /GstPipeline:pipeline0/GstXImageSink:ximagesink0
Execution ended after 0:00:05.678242793
Setting pipeline to NULL ...
But when stream on there is err info like this
[  135.430421] tegra-camrtc-capture-vi tegra-capture-vi: subdev fpga-csi 1-002b bound
[  135.431702] fpga-csi 1-002b: FPGA stream off.
[  135.431712] fpga-csi 1-002b: uih_fpga csi in probed
[  159.941080] misc tegra_camera_ctrl: tegra_camera_isomgr_request: failed to reserve 0 KBps
[  159.941319] misc tegra_camera_ctrl: tegra_camera_update_isobw: failed to reserve 0 KBps with isomgr
[  159.941955] fpga-csi 1-002b: FPGA stream on.
[  161.376638] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 164
[  163.211793] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 164
[  164.029297] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 164
[  165.497470] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 164
[  165.497800] fpga-csi 1-002b: FPGA stream off.
[  165.498836] misc tegra_camera_ctrl: tegra_camera_isomgr_request: failed to reserve 0 KBps
[  165.499069] misc tegra_camera_ctrl: tegra_camera_update_isobw: failed to reserve 0 KBps with isomgr
and here is the trace log
# tracer: nop
# entries-in-buffer/entries-written: 204/204   #P:6
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
     kworker/1:3-113     [001] ....   229.564646: rtcpu_dbg_set_loglevel: tstamp:7896768106 old:0 new:2
     kworker/1:3-113     [001] ....   234.776168: rtcpu_string: tstamp:8060162739 id:0x04010000 str:"VM0 deactivating."
        v4l2-ctl-3182    [002] ....   253.312558: tegra_channel_open: vi-output, fpga-csi 1-002b
        v4l2-ctl-3182    [002] ....   253.341528: tegra_channel_set_power: fpga-csi 1-002b : 0x1
        v4l2-ctl-3182    [002] ....   253.341532: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3182    [002] ....   253.341535: csi_s_power: enable : 0x1
        v4l2-ctl-3182    [002] ....   253.342158: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 13
        v4l2-ctl-3182    [002] ....   253.349152: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-3182    [002] ....   253.350355: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3182    [002] ....   253.350358: csi_s_stream: enable : 0x1
        v4l2-ctl-3182    [003] ....   253.351087: tegra_channel_set_stream: fpga-csi 1-002b : 0x1
 vi-output, fpga-3184    [005] ....   253.371235: tegra_channel_capture_frame: sof:276.535706304
 vi-output, fpga-3184    [005] ....   253.371237: tegra_channel_capture_frame: eof:276.552063552
 vi-output, fpga-3184    [005] ....   253.387905: tegra_channel_capture_frame: sof:276.552390112
 vi-output, fpga-3184    [005] ....   253.387906: tegra_channel_capture_frame: eof:276.568747392
     kworker/1:3-113     [001] ....   253.390542: rtcpu_string: tstamp:8641446070 id:0x04010000 str:"VM0 activating."
     kworker/1:3-113     [001] ....   253.390547: rtcpu_vinotify_error: tstamp:8641616693 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:276531700064 data:0x0000000000010000
     kworker/1:3-113     [001] ....   253.390554: rtcpu_vinotify_event: tstamp:8641891656 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276530113984 data:0xcd9ce50010000000
     kworker/1:3-113     [001] ....   253.390554: rtcpu_vinotify_event: tstamp:8641891803 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276530125728 data:0x0000000031000001
     kworker/1:3-113     [001] ....   253.390555: rtcpu_vinotify_event: tstamp:8641891965 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276530171872 data:0xcd9ce20010000000
     kworker/1:3-113     [001] ....   253.390556: rtcpu_vinotify_event: tstamp:8641892105 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276530183808 data:0x0000000031000002
     kworker/1:3-113     [001] ....   253.390556: rtcpu_vinotify_event: tstamp:8641892267 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:276531700064 data:0x0000000000010000
     kworker/1:3-113     [001] ....   253.390557: rtcpu_vinotify_event: tstamp:8641892406 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276535693632 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.390558: rtcpu_vinotify_event: tstamp:8641892569 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276535693664 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.390558: rtcpu_vinotify_event: tstamp:8641892711 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276535706304 data:0x0000000000000001
     kworker/1:3-113     [001] ....   253.390559: rtcpu_vinotify_event: tstamp:8641892870 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276535709024 data:0x0000000008020001
     kworker/1:3-113     [001] ....   253.390561: rtcpu_vinotify_event: tstamp:8642265470 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276552063008 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.390561: rtcpu_vinotify_event: tstamp:8642265633 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276552063456 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.390562: rtcpu_vinotify_event: tstamp:8642265781 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276552063488 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.390563: rtcpu_vinotify_event: tstamp:8642265942 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276552063552 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.390563: rtcpu_vinotify_event: tstamp:8642266082 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276552076384 data:0x0000000002020001
     kworker/1:3-113     [001] ....   253.390564: rtcpu_vinotify_event: tstamp:8642266240 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276552080512 data:0x0000000000020001
     kworker/1:3-113     [001] ....   253.390565: rtcpu_vinotify_event: tstamp:8642266378 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276552377472 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.390588: rtcpu_vinotify_event: tstamp:8642569726 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276552377504 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.390589: rtcpu_vinotify_event: tstamp:8642569871 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276552390112 data:0x0000000000000001
     kworker/1:3-113     [001] ....   253.390589: rtcpu_vinotify_event: tstamp:8642570029 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276552395008 data:0x0000000008020002
     kworker/1:3-113     [001] ....   253.390590: rtcpu_vinotify_event: tstamp:8642570169 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276552508736 data:0xcd9ce50010000000
     kworker/1:3-113     [001] ....   253.390590: rtcpu_vinotify_event: tstamp:8642570327 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276552520672 data:0x0000000031000003
     kworker/1:3-113     [001] ....   253.390592: rtcpu_vinotify_event: tstamp:8642787870 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276568746848 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.390593: rtcpu_vinotify_event: tstamp:8642788036 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276568747296 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.390593: rtcpu_vinotify_event: tstamp:8642788184 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276568747328 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.390594: rtcpu_vinotify_event: tstamp:8642788343 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276568747392 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.390595: rtcpu_vinotify_event: tstamp:8642788486 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276568760224 data:0x0000000002020002
     kworker/1:3-113     [001] ....   253.390595: rtcpu_vinotify_event: tstamp:8642788644 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276568764288 data:0x0000000000020002
     kworker/1:3-113     [001] ....   253.390596: rtcpu_vinotify_event: tstamp:8642788783 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276569061312 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.390597: rtcpu_vinotify_event: tstamp:8642788945 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276569061312 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.390597: rtcpu_vinotify_event: tstamp:8642789085 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276569073952 data:0x0000000000000001
     kworker/1:3-113     [001] ....   253.390598: rtcpu_vinotify_event: tstamp:8642789243 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276569076672 data:0x0000000008020003
     kworker/1:3-113     [001] ....   253.390599: rtcpu_vinotify_event: tstamp:8642789383 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276569170848 data:0xcd9ce20010000000
 vi-output, fpga-3184    [005] ....   253.404580: tegra_channel_capture_frame: sof:276.569073952
 vi-output, fpga-3184    [005] ....   253.404582: tegra_channel_capture_frame: eof:276.585431200
 vi-output, fpga-3184    [005] ....   253.421320: tegra_channel_capture_frame: sof:276.585757792
 vi-output, fpga-3184    [005] ....   253.421321: tegra_channel_capture_frame: eof:276.602115040
     kworker/1:3-113     [001] ....   253.446546: rtcpu_vinotify_event: tstamp:8643112411 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276569208160 data:0x0000000031000004
     kworker/1:3-113     [001] ....   253.446551: rtcpu_vinotify_event: tstamp:8643451467 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276585430688 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.446552: rtcpu_vinotify_event: tstamp:8643451628 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276585431104 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.446553: rtcpu_vinotify_event: tstamp:8643451778 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276585431136 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.446553: rtcpu_vinotify_event: tstamp:8643451939 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276585431200 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.446554: rtcpu_vinotify_event: tstamp:8643452082 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276585444000 data:0x0000000002020003
     kworker/1:3-113     [001] ....   253.446555: rtcpu_vinotify_event: tstamp:8643452240 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276585448160 data:0x0000000000020003
     kworker/1:3-113     [001] ....   253.446555: rtcpu_vinotify_event: tstamp:8643452379 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276585745120 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.446556: rtcpu_vinotify_event: tstamp:8643452545 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276585745152 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.446556: rtcpu_vinotify_event: tstamp:8643452687 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276585757792 data:0x0000000000000001
     kworker/1:3-113     [001] ....   253.446557: rtcpu_vinotify_event: tstamp:8643452847 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276585760512 data:0x0000000008020004
     kworker/1:3-113     [001] ....   253.446558: rtcpu_vinotify_event: tstamp:8643819632 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276602114528 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.446582: rtcpu_vinotify_event: tstamp:8643819797 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276602114976 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.446583: rtcpu_vinotify_event: tstamp:8643819942 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276602114976 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.446583: rtcpu_vinotify_event: tstamp:8643820103 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276602115040 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.446584: rtcpu_vinotify_event: tstamp:8643820242 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276602127840 data:0x0000000002020004
     kworker/1:3-113     [001] ....   253.446585: rtcpu_vinotify_error: tstamp:8643827475 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276602441600 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.446586: rtcpu_vinotify_event: tstamp:8644129667 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276602134144 data:0x0000000000020004
     kworker/1:3-113     [001] ....   253.446587: rtcpu_vinotify_event: tstamp:8644129820 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276602428992 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.446588: rtcpu_vinotify_event: tstamp:8644129984 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276602441600 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.446588: rtcpu_vinotify_error: tstamp:8644348843 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276619125472 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.446589: rtcpu_vinotify_event: tstamp:8644468643 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276618798784 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.446590: rtcpu_vinotify_event: tstamp:8644468801 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276619112800 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.446590: rtcpu_vinotify_event: tstamp:8644468957 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276619125472 data:0x00000000000003c9
 vi-output, fpga-3184    [004] ....   253.471701: tegra_channel_capture_frame: sof:276.635809280
 vi-output, fpga-3184    [004] ....   253.471705: tegra_channel_capture_frame: eof:276.652166560
     kworker/1:3-113     [001] ....   253.502552: rtcpu_vinotify_event: tstamp:8644807630 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276624556064 data:0xcd9ce50010000000
     kworker/1:3-113     [001] ....   253.502555: rtcpu_vinotify_event: tstamp:8644807778 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276624567840 data:0x0000000031000005
     kworker/1:3-113     [001] ....   253.502557: rtcpu_vinotify_error: tstamp:8644870899 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:276635796640 data:0x00000000000000a4
     kworker/1:3-113     [001] ....   253.502563: rtcpu_vinotify_event: tstamp:8645146816 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:276635796640 data:0x00000000000000a4
     kworker/1:3-113     [001] ....   253.502564: rtcpu_vinotify_event: tstamp:8645146959 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276635796640 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.502565: rtcpu_vinotify_event: tstamp:8645147131 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276635796672 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.502565: rtcpu_vinotify_event: tstamp:8645147271 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276635809280 data:0x0000000000000001
     kworker/1:3-113     [001] ....   253.502566: rtcpu_vinotify_event: tstamp:8645147429 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276635811936 data:0x0000000008020005
     kworker/1:3-113     [001] ....   253.502567: rtcpu_vinotify_event: tstamp:8645383917 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276652166016 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.502568: rtcpu_vinotify_event: tstamp:8645384079 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276652166464 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.502569: rtcpu_vinotify_event: tstamp:8645384226 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276652166496 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.502569: rtcpu_vinotify_error: tstamp:8645391579 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276652493120 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.502597: rtcpu_vinotify_event: tstamp:8645689452 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276652166560 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.502598: rtcpu_vinotify_event: tstamp:8645689595 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276652182560 data:0x0000000002020005
     kworker/1:3-113     [001] ....   253.502598: rtcpu_vinotify_event: tstamp:8645689754 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276652186720 data:0x0000000000020005
     kworker/1:3-113     [001] ....   253.502599: rtcpu_vinotify_event: tstamp:8645689893 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276652480480 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.502599: rtcpu_vinotify_event: tstamp:8645690054 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276652493120 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.502601: rtcpu_vinotify_error: tstamp:8645912951 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276669176960 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.502602: rtcpu_vinotify_event: tstamp:8646028424 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276668850272 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.502603: rtcpu_vinotify_event: tstamp:8646028585 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276669164288 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.502603: rtcpu_vinotify_event: tstamp:8646028726 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276669176960 data:0x00000000000003c9
 vi-output, fpga-3184    [004] ....   253.538076: tegra_channel_capture_frame: sof:276.702544608
 vi-output, fpga-3184    [004] ....   253.538079: tegra_channel_capture_frame: eof:276.718901856
     kworker/1:3-113     [001] ....   253.562552: rtcpu_vinotify_error: tstamp:8646434355 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276685860768 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.562556: rtcpu_vinotify_event: tstamp:8646706745 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276685534112 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.562557: rtcpu_vinotify_event: tstamp:8646706890 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276685848128 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.562558: rtcpu_vinotify_event: tstamp:8646707061 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276685860768 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.562558: rtcpu_vinotify_event: tstamp:8646707204 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276691623008 data:0xcd9ce20010000000
     kworker/1:3-113     [001] ....   253.562559: rtcpu_vinotify_event: tstamp:8646707367 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276691634784 data:0x0000000031000006
     kworker/1:3-113     [001] ....   253.562565: rtcpu_vinotify_event: tstamp:8646957245 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276702217952 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.562566: rtcpu_vinotify_event: tstamp:8646957405 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276702531968 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.562567: rtcpu_vinotify_event: tstamp:8646957551 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276702531968 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.562567: rtcpu_vinotify_event: tstamp:8647283006 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276702544608 data:0x0000000000000001
     kworker/1:3-113     [001] ....   253.562568: rtcpu_vinotify_event: tstamp:8647283150 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276702549472 data:0x0000000008020006
     kworker/1:3-113     [001] ....   253.562569: rtcpu_vinotify_error: tstamp:8647477057 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276719228448 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.562570: rtcpu_vinotify_event: tstamp:8647622075 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276718901344 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.562571: rtcpu_vinotify_event: tstamp:8647622219 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276718901792 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.562571: rtcpu_vinotify_event: tstamp:8647622384 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276718901824 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.562596: rtcpu_vinotify_event: tstamp:8647622524 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276718901856 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.562597: rtcpu_vinotify_event: tstamp:8647622722 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276718914688 data:0x0000000002020006
     kworker/1:3-113     [001] ....   253.562598: rtcpu_vinotify_event: tstamp:8647622868 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276718918816 data:0x0000000000020006
     kworker/1:3-113     [001] ....   253.562598: rtcpu_vinotify_event: tstamp:8647623028 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276719215808 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.562599: rtcpu_vinotify_event: tstamp:8647623170 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276719228448 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.562600: rtcpu_vinotify_error: tstamp:8647998469 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276735912288 data:0x00000000000003c9
 vi-output, fpga-3184    [004] ....   253.588154: tegra_channel_capture_frame: sof:276.752596128
 vi-output, fpga-3184    [004] ....   253.588156: tegra_channel_capture_frame: eof:276.768953376
     kworker/1:3-113     [001] ....   253.622522: rtcpu_vinotify_event: tstamp:8648300364 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276735585632 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.622525: rtcpu_vinotify_event: tstamp:8648300506 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276735899616 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.622526: rtcpu_vinotify_event: tstamp:8648300668 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276735912288 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.622527: rtcpu_vinotify_event: tstamp:8648509544 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276746692224 data:0xcd9ce50010000000
     kworker/1:3-113     [001] ....   253.622527: rtcpu_vinotify_event: tstamp:8648509724 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276746703936 data:0x0000000031000007
     kworker/1:3-113     [001] ....   253.622528: rtcpu_vinotify_event: tstamp:8648509867 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276752269440 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.622532: rtcpu_vinotify_event: tstamp:8648842927 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276752583456 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.622533: rtcpu_vinotify_event: tstamp:8648843076 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276752583488 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.622533: rtcpu_vinotify_event: tstamp:8648843238 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276752596128 data:0x0000000000000001
     kworker/1:3-113     [001] ....   253.622534: rtcpu_vinotify_event: tstamp:8648843378 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276752598816 data:0x0000000008020007
     kworker/1:3-113     [001] ....   253.622536: rtcpu_vinotify_error: tstamp:8649041178 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276769279936 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.622537: rtcpu_vinotify_event: tstamp:8649182062 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276768952864 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.622537: rtcpu_vinotify_event: tstamp:8649182205 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276768953280 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.622538: rtcpu_vinotify_event: tstamp:8649182371 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276768953312 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.622539: rtcpu_vinotify_event: tstamp:8649182511 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276768953376 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.622539: rtcpu_vinotify_event: tstamp:8649182669 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276768966208 data:0x0000000002020007
     kworker/1:3-113     [001] ....   253.622560: rtcpu_vinotify_event: tstamp:8649182809 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276768970304 data:0x0000000000020007
     kworker/1:3-113     [001] ....   253.622561: rtcpu_vinotify_event: tstamp:8649182967 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276769267296 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.622562: rtcpu_vinotify_event: tstamp:8649183109 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276769279936 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.622562: rtcpu_vinotify_error: tstamp:8649562542 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276785963776 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.622563: rtcpu_vinotify_event: tstamp:8649834387 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276785637120 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.622564: rtcpu_vinotify_event: tstamp:8649834535 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276785951104 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.622564: rtcpu_vinotify_event: tstamp:8649834697 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276785963776 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.622565: rtcpu_vinotify_event: tstamp:8649834841 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276794605632 data:0xcd9ce20010000000
 vi-output, fpga-3184    [004] ....   253.638181: tegra_channel_capture_frame: sof:276.802647616
 vi-output, fpga-3184    [004] ....   253.638183: tegra_channel_capture_frame: eof:276.819004864
 vi-output, fpga-3184    [004] ....   253.654851: tegra_channel_capture_frame: sof:276.819331424
 vi-output, fpga-3184    [004] ....   253.654853: tegra_channel_capture_frame: eof:276.835688704
     kworker/1:3-113     [001] ....   253.678526: rtcpu_vinotify_event: tstamp:8650165405 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276794641440 data:0x0000000031000008
     kworker/1:3-113     [001] ....   253.678529: rtcpu_vinotify_event: tstamp:8650165554 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276794698176 data:0xcd9ce50010000000
     kworker/1:3-113     [001] ....   253.678529: rtcpu_vinotify_event: tstamp:8650165716 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276794710176 data:0x0000000031000009
     kworker/1:3-113     [001] ....   253.678530: rtcpu_vinotify_event: tstamp:8650165856 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276802320960 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.678531: rtcpu_vinotify_event: tstamp:8650166016 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276802634976 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.678531: rtcpu_vinotify_event: tstamp:8650166161 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276802634976 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.678532: rtcpu_vinotify_event: tstamp:8650166322 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276802647616 data:0x0000000000000001
     kworker/1:3-113     [001] ....   253.678533: rtcpu_vinotify_event: tstamp:8650166463 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276802650336 data:0x0000000008020008
     kworker/1:3-113     [001] ....   253.678554: rtcpu_vinotify_event: tstamp:8650606847 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276819004352 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.678555: rtcpu_vinotify_event: tstamp:8650606987 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276819004800 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.678556: rtcpu_vinotify_event: tstamp:8650607153 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276819004800 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.678557: rtcpu_vinotify_event: tstamp:8650607294 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276819004864 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.678557: rtcpu_vinotify_event: tstamp:8650607454 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276819017696 data:0x0000000002020008
     kworker/1:3-113     [001] ....   253.678558: rtcpu_vinotify_event: tstamp:8650607594 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276819021792 data:0x0000000000020008
     kworker/1:3-113     [001] ....   253.678559: rtcpu_vinotify_event: tstamp:8650607752 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276819318784 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.678559: rtcpu_vinotify_event: tstamp:8650607901 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276819318784 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.678560: rtcpu_vinotify_event: tstamp:8650911312 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276819331424 data:0x0000000000000001
     kworker/1:3-113     [001] ....   253.678560: rtcpu_vinotify_event: tstamp:8650911455 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276819336320 data:0x0000000008020009
     kworker/1:3-113     [001] ....   253.678562: rtcpu_vinotify_error: tstamp:8651126650 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276836015296 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.678563: rtcpu_vinotify_event: tstamp:8651250405 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276835688160 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.678564: rtcpu_vinotify_event: tstamp:8651250545 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276835688608 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.678565: rtcpu_vinotify_event: tstamp:8651250710 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276835688640 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.678565: rtcpu_vinotify_event: tstamp:8651250850 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276835688704 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.678566: rtcpu_vinotify_event: tstamp:8651251009 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276835701536 data:0x0000000002020009
     kworker/1:3-113     [001] ....   253.678567: rtcpu_vinotify_event: tstamp:8651251151 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276835705632 data:0x0000000000020009
     kworker/1:3-113     [001] ....   253.678567: rtcpu_vinotify_event: tstamp:8651251310 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276836002624 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.678568: rtcpu_vinotify_event: tstamp:8651251454 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:276836015296 data:0x00000000000003c9
     kworker/1:3-113     [001] ....   253.678569: rtcpu_vinotify_event: tstamp:8651589469 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276840729696 data:0xcd9ce20010000000
     kworker/1:3-113     [001] ....   253.678569: rtcpu_vinotify_event: tstamp:8651589615 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276840741472 data:0x000000003100000a
     kworker/1:3-113     [001] ....   253.678571: rtcpu_vinotify_event: tstamp:8651649539 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276852372448 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.678572: rtcpu_vinotify_event: tstamp:8651649679 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:276852686464 data:0x0000000000000014
     kworker/1:3-113     [001] ....   253.678573: rtcpu_vinotify_event: tstamp:8651649845 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:276852686496 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.678574: rtcpu_vinotify_event: tstamp:8651649989 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:276852699104 data:0x0000000000000001
 vi-output, fpga-3184    [004] ....   253.688196: tegra_channel_capture_frame: sof:276.852699104
 vi-output, fpga-3184    [004] ....   253.688197: tegra_channel_capture_frame: eof:276.869056384
        v4l2-ctl-3182    [003] ....   253.688239: tegra_channel_set_stream: enable : 0x0
        v4l2-ctl-3182    [003] ....   253.688242: tegra_channel_set_stream: fpga-csi 1-002b : 0x0
        v4l2-ctl-3182    [003] ....   253.688263: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3182    [003] ....   253.688265: csi_s_stream: enable : 0x0
        v4l2-ctl-3182    [003] ....   253.689678: tegra_channel_set_power: fpga-csi 1-002b : 0x0
        v4l2-ctl-3182    [003] ....   253.689680: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3182    [003] ....   253.689683: csi_s_power: enable : 0x0
     kworker/1:3-113     [001] ....   253.734520: rtcpu_vinotify_event: tstamp:8651962428 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276852704000 data:0x000000000802000a
     kworker/1:3-113     [001] ....   253.734528: rtcpu_vinotify_event: tstamp:8652301646 cch:-1 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:276869055840 data:0x00000000086f0002
     kworker/1:3-113     [001] ....   253.734529: rtcpu_vinotify_event: tstamp:8652301821 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:276869056288 data:0x0000000000000024
     kworker/1:3-113     [001] ....   253.734529: rtcpu_vinotify_event: tstamp:8652301970 cch:-1 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:276869056288 data:0x0000000800000000
     kworker/1:3-113     [001] ....   253.734530: rtcpu_vinotify_event: tstamp:8652302127 cch:-1 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:276869056384 data:0x0000000000000000
     kworker/1:3-113     [001] ....   253.734531: rtcpu_vinotify_event: tstamp:8652302265 cch:-1 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276869069184 data:0x000000000202000a
     kworker/1:3-113     [001] ....   253.734531: rtcpu_vinotify_event: tstamp:8652302424 cch:-1 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:276869073280 data:0x000000000002000a
        v4l2-ctl-3182    [001] ....   254.612369: tegra_channel_close: vi-output, fpga-csi 1-002b
     kworker/1:3-113     [001] ....   259.390019: rtcpu_string: tstamp:8828702042 id:0x04010000 str:"VM0 deactivating."
since fpga gives tpg, we can get the first frame data and check its okay. And there is no err info
v4l2-ctl --set-fmt-video=width=3840,height=2160,pixelformat=UYVY --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=test.raw
[  189.276833] misc tegra_camera_ctrl: tegra_camera_isomgr_request: failed to reserve 0 KBps
[  189.277088] misc tegra_camera_ctrl: tegra_camera_update_isobw: failed to reserve 0 KBps with isomgr
[  189.277740] fpga-csi 1-002b: FPGA stream on.
[  189.405424] fpga-csi 1-002b: FPGA stream off.
[  189.406238] misc tegra_camera_ctrl: tegra_camera_isomgr_request: failed to reserve 0 KBps
[  189.406491] misc tegra_camera_ctrl: tegra_camera_update_isobw: failed to reserve 0 KBps with isomgr
But when get more frame, err info comes out
v4l2-ctl --set-fmt-video=width=3840,height=2160,pixelformat=UYVY --stream-mmap --stream-count=5 -d /dev/video0 --stream-to=test.raw
[  253.349875] misc tegra_camera_ctrl: tegra_camera_isomgr_request: failed to reserve 0 KBps
[  253.350117] misc tegra_camera_ctrl: tegra_camera_update_isobw: failed to reserve 0 KBps with isomgr
[  253.351094] fpga-csi 1-002b: FPGA stream on.
[  253.471377] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 164
[  253.688254] fpga-csi 1-002b: FPGA stream off.
[  253.689181] misc tegra_camera_ctrl: tegra_camera_isomgr_request: failed to reserve 0 KBps
[  253.689441] misc tegra_camera_ctrl: tegra_camera_update_isobw: failed to reserve 0 KBps with isomgr
And here is our driver which not used tegracam format.
fpga.txt (7.6 KB)
hello 854053437,
the error log above looks you’ve not configure environment variable to render display,
please give it a try to set export DISPLAY=:0, and then check with xrandr for confirmation.
it seems there’re valid frame packets on the CSI channel.
as you can see, there’re pair of CHANSEL_PXL_SOF/CHANSEL_PXL_EOF to indicate a frame has detected by VI engine. afterwards, it’s ATOMP_FRAME_DONE to indicate it’s complete writing a frame to memory.
discarding frame meant there’s an error of capture status.
it should not a fatal error since it’s a correctable error, (i.e. corr_err).
err_data 164 shows there’s FS_FAULT. the receiver is getting packets, but not consistently.
let’s double check your FPGA output.
for instance,
if you’re using virtual channel IDs, VC must match DT/driver.
please confirm the data type, it must be YUV422 8-bit per your tracing logs.
you may examine the frame sequence, no stale/spurious packets before first FS after stream-on.
besides.. please review DT, pix_clk_hz/line_length/framerate should reflect real sensor timing.
Hi, Jerry
This is not err, just I manully closed the stream window
I’ll check with our FPGA parnter.
And for the DT, since our driver is not used tegra format, the mode node is not configured.
And its very strange our DT is as below, when used tegracam driver we’ll enable mode node, there is only black and no data reciecved
and used v4l2 standard driver above, we comment mode node and can get data in
    i2c@c240000 {
        uih_rtc: uih_rtc@68 {
			status = "okay";
            compatible = "ds1340";
            reg = <0x68>;
		uih_fpga: uih_fpga@2b {
			status = "okay";
			compatible = "uih,fpga";
			reg = <0x2b>;
			devnode = "video0";
			// interrupt-parent = <&tegra_aon_gpio>;
			// interrupts = <TEGRA194_AON_GPIO(CC, 0) IRQ_TYPE_LEVEL_LOW>;
            // mode0 {
            //     mclk_khz = "24000";
            //     num_lanes = "4";
            //     tegra_sinterface = "serial_e";
            //     phy_mode = "DPHY";
            //     discontinuous_clk = "no";
            //     dpcm_enable = "false";
            //     cil_settletime = "0";
            //     active_w = "3840";
            //     active_h = "2160";
            //     mode_type = "yuv";
            //     pixel_phase = "uyvy";
            //     csi_pixel_bit_depth = "16";
            //     readout_orientation = "0";
            //     line_length = "11200";
            //     inherent_gain = "1";
            //     mclk_multiplier = "80";
            //     pix_clk_hz = "840000000";
            //     gain_factor = "16";
            //     framerate_factor = "1000000";
            //     exposure_factor = "1000000";
            //     min_gain_val = "16"; /* 1.00x */
            //     max_gain_val = "356"; /* 22x */
            //     step_gain_val = "1";
            //     default_gain = "16"; /* 1.00x */
            //     min_hdr_ratio = "1";
            //     max_hdr_ratio = "1";
            //     min_framerate = "2000000"; /* 2.0 fps */
            //     max_framerate = "60000000"; /* 60.0 fps */
            //     step_framerate = "1";
            //     default_framerate = "60000000"; /* 60.0 fps */
            //     min_exp_time = "13"; /* us */
            //     max_exp_time = "683709"; /* us */
            //     step_exp_time = "1";
            //     default_exp_time = "2495"; /* us */
            //     embedded_metadata_height = "0";
            // mode1 {
            //     num_lanes = "4";
            //     active_w = "1920";
            //     active_h = "1080";
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					status = "okay";
					fpga2csi_out0: endpoint {
						status = "okay";
						port-index = <4>;
						bus-width = <4>;
						remote-endpoint = <&fpga2csi_csi_in0>;
	tegra-capture-vi  {
		num-channels = <1>;
		status = "okay";
		ports {
			#size-cells = <0>;
			port@0 {
				status = "okay";
				reg = <0>;
				fpga2csi_vi_in0: endpoint {
					status = "okay";
					port-index =<4>;
					bus-width = <4>;
					remote-endpoint = <&fpga2csi_csi_out0>;
    /* LT6911UXE & HDMI */
	host1x@13e00000 {
		display-hub@15200000 {
            display@15200000 {
                bootloader-status = "disabled";
            display@15210000 {
            display@15220000 {
            display@15230000 {
		sor {
            status = "okay";
            // /delete-property/ nvidia,hpd-gpio;
            nvidia,active-panel = <&sor0_hdmi_display>;
            hdmi-display {
                status = "okay";
            dp-display {
        sor1 {
            status = "okay";
            nvidia,active-panel = <&sor1_hdmi_display>;
            hdmi-display {
                status = "okay";
            dp-display {
        sor2 {
        sor3 {
		dpaux@155F0000 {
		nvcsi@15a00000 {
			num-channels = <1>;
			#size-cells = <0>;
			status = "okay";
			channel@0 {
				status = "okay";
				reg = <0>;
				ports {
					#size-cells = <0>;
					port@0 {
						status = "okay";
						reg = <0>;
						fpga2csi_csi_in0: endpoint@0 {
							status = "okay";
							port-index = <4>;
							bus-width = <4>;
							remote-endpoint = <&fpga2csi_out0>;
					port@1 {
						status = "okay";
						reg = <1>;
						fpga2csi_csi_out0: endpoint@1 {
							status = "okay";
							remote-endpoint = <&fpga2csi_vi_in0>;
	tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		num_csi_lanes = <4>;
		max_lane_speed = <1500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <750000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		modules {
			module0 {
				badge = "uih_fpga2csi_rear";
				position = "rear";
				status = "okay";
				orientation = "1";
				drivernode0 {
					/* Declare PCL support driver (classically known as guid)  */
					pcl_id = "v4l2_sensor";
					devname = "uih-fpga 0-002b";
					status = "okay";
					/* Declare the device-tree hierarchy to driver instance */
					proc-device-tree = "/proc/device-tree/i2c@c240000/uih_fpga@2b";
Hi, Jerry
We make FPGA send data after stream on
And get different err
[  156.932854] misc tegra_camera_ctrl: tegra_camera_isomgr_request: failed to reserve 0 KBps
[  156.933100] misc tegra_camera_ctrl: tegra_camera_update_isobw: failed to reserve 0 KBps with isomgr
[  156.933697] fpga-csi 1-002b: FPGA stream on.
[  159.444541] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  161.890963] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  162.068106] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  162.985420] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  163.505557] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  164.014656] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  164.506095] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  164.990841] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  165.573194] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  166.072700] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  166.558565] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  167.079226] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  167.562420] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  168.060192] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  168.548433] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  169.052766] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  169.541891] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  170.023836] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  170.516192] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  170.982837] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  171.465086] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  173.760463] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  174.457603] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 0
[  174.458095] fpga-csi 1-002b: FPGA stream off.
[  174.459018] misc tegra_camera_ctrl: tegra_camera_isomgr_request: failed to reserve 0 KBps
[  174.459302] misc tegra_camera_ctrl: tegra_camera_update_isobw: failed to reserve 0 KBps with isomgr
And we can see the tpg show on in gstreamer window after FPGA send data. What does err_data 0 mean?
hello 854053437,
may I know what’s the sensor frame-rate?
is it 2-fps? is looks you’ve discarding frame reported around ~500ms every-line.
as mentioned by Topic 367706.
since this is not a standard camera sensor, you may also give it a try to comment frame_err for testing.
Hi, Jerry
our FPGA output 54 or 60 fps stream.
I’ll try to comment this for testing.
Up to now, we can stream FPGA’s tpg video with gstreamer and there is only this err info show up. We’ll test more to see if there is any more err.
Hi, Jerry
When we test 55pfs stream, obvious line‑shift distortion can be observed on the top several rows of the captured frame.
Here is 60 pfs stream
And Here is 55fps stream
And we have commented frame_err in vi driver.
hello 854053437,
is it display related? it looks display tearing instead of CSI corruption.
did you check the raw content, let’s have verify with file capture for confirmation.
for instance,
$ gst-launch-1.0 -e v4l2src device=/dev/video0 num-buffers=1 ! 'video/x-raw,format=UYVY,width=3840,height=2160,framerate=55/1' ! videoconvert ! pngenc ! filesink location=fpga_55fps.png
if the saved PNG/raw frame also has shifted top rows, then it is a real capture issue.
Hi, Jerry
I saved the PNG/raw and the frame has still shifted top rows
hello 854053437,
since the artifact exists in a saved frame, then 55-fps is likely changing FPGA MIPI timing or frame-start/line-start sequencing.
you may also check with the FPGA vendor to confirm the mode timing.
for instance,
(1) is 55-fps mode change the MIPI lane clock/timing?
(2) if 55-fps mode keep the same MIPI lane rate, it shall has increase vertical blanking.
(3) you may verify D-PHY timing, settle timing, and FPGA LP/HS behavior.
(4) or.. you’ve the driver hardcodes as 60-fps while FPGA outputs 55-fps?
Hi, Jerry
because of hardware design deficiency, we only have mipi data connected to FPGA.
So in my driver, I set s_frame_interval and g_frame_interval to change fps and default is 60.
When I use
v4l2-ctl -d /dev/v4l-subdev1 --set-subdev-fps pad=0,fps=55
set it to 55fps.
I can get the frame right like this
But with stream on, there is still top shifted
Is this gstreamer display issuse?
you may add some debug message to check whether it’s launching camera with the default 60-fps timings
Hi, Jerry
It seems that I missed the top line in picture. It’s the same result wthether if I set the fps.
Sorry for that
And I’ll check other information with our FPGA friend.
Hi, Jerry
We met a issuse when apply real video not tpg.
The out stream picture’color is err
like its not yuv422 but rgb, because the black becomes green in stream
log is as below
hello 854053437,
here’s see-also discussion thread, Topic 380857. it may caused by actual byte order differs from advertised fourcc.
you may examine sensor capability, and update device tree pixel_phase property to match your hardware settings.
Hi, Jerry
we capture one frame and use 7yuv to see
it’s correct in YUYV
And bad in UYVY
Because our driver is not used nvidia format, so we did not have mode node in dts. this usage is okay with our lt6911 driver.
I’ll try to modify driver to see if pixel_phase can fix this
