I am working on a video processing pipeline for the Jetson Xavier NX as part of a larger device. It receives the video signal via an MIPI TX CSI-2 interface, but when the camera signal is briefly interrupted, e.g., by (physically) disconnecting and reconnecting the camera, the signal does not reach the GPU any more. Even rebooting the GPU from the console does not fix it, only turning the power off and on works.
I tried to investigate this and learned that rebooting the GPU does not also reboot the NVCSI / VI because they are separate hardware, is that correct? Is there a way to do this from the GPU?
This low-level and hardware architecture is currently pretty much beyond my understanding, but I believe it looks something like this:
FPGA → CSI-2 → NVCSI → RCE → VI → my video processing pipeline (V4L2 → DMABUF, VIC, CUDA, EGL).
Note that the error seems not to be caused by my pipeline, since I can also confirm it by just using V4L2 from the terminal, e.g. via v4l2-ctl --stream-mmap --stream-count=1 -d /dev/video0. Running dmesg then shows (the errors only appear once V4L2 tries to access the video stream, otherwise the system seems to fail “silently”, i.e., so far, I could not find any signs of it before trying to access the video stream):
[ 494.826473] [fpga] fpga_power_on called
[ 494.826512] [fpga] fpga_power_on set mclk to 24000000 Hz
[ 497.376067] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 497.376103] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 497.376167] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 497.376185] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 497.376223] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 497.376656] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 497.432060] [RCE] ERROR: camera-ip/vi5/vi5.c:3913 [vi5_update_channel_match_data] "match configuration is already in use by by channel 35 cannot set channel match configuration"
[ 497.432071] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[ 499.921875] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 499.921911] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 499.921963] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 499.921980] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 499.921995] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 499.922033] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
So the error seems to occur somewhere in the FPGA / NVCSI / RCE / VI section. So far, I wasn’t able to narrow it down any further.
Some additional information that may be helpful
media-ctl -p provides:
Media controller API version 5.10.192
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.10.192
Device topology
- entity 1: 13e10000.host1x:nvcsi@15a00000- (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
<- "fpga 9-0032":0 [ENABLED]
pad1: Source
-> "vi-output, fpga 9-0032":0 [ENABLED]
- entity 4: 13e10000.host1x:nvcsi@15a00000- (2 pads, 2 links)
device node name /dev/v4l-subdev1
pad0: Sink
<- "fpga 10-0036":0 [ENABLED]
pad1: Source
-> "vi-output, fpga 10-0036":0 [ENABLED]
- entity 7: fpga 9-0032 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
[fmt:UYVY10_1X20/1920x1080 field:none colorspace:srgb]
-> "13e10000.host1x:nvcsi@15a00000-":0 [ENABLED]
- entity 9: vi-output, fpga 9-0032 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "13e10000.host1x:nvcsi@15a00000-":1 [ENABLED]
- entity 23: fpga 10-0036 (1 pad, 1 link)
device node name /dev/v4l-subdev3
pad0: Source
- entity 25: vi-output, fpga 10-0036 (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
v4l2-ctl --all -d /dev/video0 provides:
Driver Info:
Driver name : tegra-video
Card type : vi-output, fpga 9-0032
Bus info : platform:tegra-capture-vi:0
Driver version : 5.10.192
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Driver name : tegra-camrtc-ca
Model : NVIDIA Tegra Video Input Device
Serial :
Bus info :
Media version : 5.10.192
Hardware revision: 0x00000003 (3)
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, fpga 9-0032
Function : V4L2 I/O
Pad 0x0100000a : 0: Sink
Link 0x0200000f: from remote pad 0x1000003 of entity '13e10000.host1x:nvcsi@15a00000-': Data, Enabled
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'UY20' (UYVY 4:2:2 10 bit)
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
hdr_enable 0x009a2004 (intmenu): min=0 max=1 default=0 value=0
0: 0 (0x0)
1: 1 (0x1)
gain 0x009a2009 (int64) : min=16 max=171 step=1 default=16 value=16 flags=slider
exposure 0x009a200a (int64) : min=13 max=683710 step=1 default=2495 value=13 flags=slider
frame_rate 0x009a200b (int64) : min=2000000 max=60000000 step=1 default=60000000 value=2000000 flags=slider
exposure_short 0x009a200c (int64) : min=13 max=683709 step=1 default=2495 value=13 flags=slider
sensor_configuration 0x009a2032 (u32) : min=0 max=4294967295 step=1 default=0 [22] flags=read-only, volatile, has-payload
sensor_mode_i2c_packet 0x009a2033 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
sensor_control_i2c_packet 0x009a2034 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
0: 0 (0x0)
1: 1 (0x1)
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
0: 0 (0x0)
1: 1 (0x1)
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
0: 1 (0x1)
1: 65536 (0x10000)
2: 131072 (0x20000)
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=4 flags=read-only
v4l2-ctl -d /dev/v4l-subdev2 --all provides:
Camera Controls
0: 0 (0x0)
1: 1 (0x1)
