FPR indexing within kernels; Sequential separate host accumulation( float + long long unsigned );
  1. Floating point register ( FPR ) indexing within kernels should be efficient as long as there is only a single dedicated integer register and 128 FPR’s in single hardware-CUDA core:
const uint32_t nThreads = 512, nBlocks = ( N / nThreads ) + 1;
if ( ( nThreads * nBlocks ) > 16777215 ) { printf( "FPR addressing error!\n" ); return; };
__global__ void fooKernel( float *d_in )
//   max FPR indexing: nThreads=512; nBlocks=32767; (floatIndex < 16777215 ~=64GB)
	float tdx = threadIdx.x + blockIdx.x * blockDim.x;
        printf( "thread[%i].block[%i]\n", uint32_t( tdx ), blockDim.x );
  1. Cumulative error is silent error proner - even with usage of 64bit double. Please do consider host code with sequential separate accumulation:
template < typename T >
inline T localAccumulate( vector< T >& inVal )
    uint16_t lloverflow = 0;                                   //positive overflow counter
    long long int llArr[ 3 ] = { 0, 0 };                       //[0] - tmp LL; [1] - accumulator;
    float f32fract = 0.0f;
    for ( auto &x : inVal )
	llArr[ 0 ] = ( long long int )x;
	f32fract += float( x ) - float( llArr[ 0 ] );
        if ( llArr[ 0 ] + llArr[ 1 ] > LLONG_MAX )            //long long int positive overflow only
            lloverflow++;
	llArr[ 1 ] += llArr[ 0 ];
	if ( ( f32fract > 9.9f ) || ( f32fract < -9.9f ) )    //minimizing cumulative error - both positive and negative
	    llArr[ 0 ] = ( long long int )f32fract;
	    f32fract -= llArr[ 0 ];
    return f32fract + ( float )( llArr[ 1 ] ) + ( float )( ( LLONG_MAX * lloverflow ) );
Post Scriptum: some C++11/CUDA C++11/LINUX programming examples are uploaded at free repository:
https://github.com/PiotrLenarczykAnonim
The GPU uses the same set of 32-bit registers for all data, so there is no distinction between integer and floating-point registers. Instructions operating on 64-bit data types access pairs of consecutive registers starting with an even-numbered register.
Using floating-point types for array indexing would seem to (1) increase dynamic instruction count due to necessary conversion instructions (2) inhibit common compiler optimization for indexing / address arithmetic. In other words, this is unlikely to be beneficial to code performance.
I am not an expert in CUDA-hardware, thank you for reply with FPR’s.
