FPS control
• DeepStream Version: 6.3
While my process is executing, I want to continuously save the frames per second (fps) of my stream in order to maintain control over it within a specific threshold.
I print the FPS using perf_data.update_fps(stream_index) but I’m unable to retrieve it into variables for control purposes.
Is there a solution to accomplish this?
Could you describe exactly what the control purposes are?
I need to manipulate while it lower below the threshold it generate an alert or print in console
You can customize your own needs in the source code FPS.py.
Thank you for your reply.
I have already customized the source code and found the solution.
Thank you for your time.
