• Hardware Platform (GPU):- T4
• DeepStream Version:- 6.0
• JetPack Version (valid for Jetson only):- NA
• TensorRT Version:- 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only):- 610.43.02
• Issue Type( questions, new requirements, bugs):- Bug
We are observing a performance degradation while parsing camera RTSP streams, where the processed FPS is consistently lower on our upgraded cluster compared to the earlier environment.
The same application code and RTSP camera streams are being used in both environments. The application consistently achieves approximately 10 FPS on the earlier environment, whereas after upgrading the underlying software stack, the FPS has dropped to approximately 8 FPS.
Performance Comparison
| Environment | FPS |
| Earlier environment | ~10 FPS consistently |
| Upgraded environment | ~8 FPS |
| Observed degradation | ~20% |
Key Observation
The issue is observed only after upgrading the infrastructure/software components. The application code has not changed between the two environments.
The upgraded cluster includes newer versions of:
- Operating System
- Kubernetes
- NVIDIA Driver / NVIDIA-SMI
- CUDA
- Linux Kernel
The same code performs normally on the earlier versions of these components.
Environment Details are as follows
| S.No | component | Earlier Version | New Version on which issue is coming |
| 1 | Server | HP - DL380Gen10 | HP - DL380Gen10 |
| 2 | Processor | AMD EPYC 7742 64-Core Processor | AMD EPYC 7742 64-Core Processor |
| 3 | GPU | T4 | T4 |
| 4 | Ubuntu OS | 18.04.02 LTS | 24.04.4 LTS |
| 5 | K8s | 1.16.2 | v1.35.5 |
| 6 | Docker / CRI-O | 19.3.13 (Docker) | 1.35.3 (CRI-O) |
| 7 | NVIDIA-SMI | 510.47.03 | 610.43.02 |
| 8 | CUDA | 11.6 | 13.3 |
| 10 | KERNEL-VERSION | 4.15.0-197-generic | 6.8.0-134-generic |
| 11 | Triton inference Server | 22.02 | 22.02 |
| 12 | DeepStream SDK | 6.0 | 6.0 |
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing):- Try to reproduce on the upgraded versions of OS,K8s, CUDA etc as mentioned above.
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description):- We are using the RTSP camera stream for Face recognition application.
What We Have Observed
- RTSP streams are accessible and the application is able to receive frames.
- No corresponding change has been made to the application code.
- Earlier environment consistently delivers ~10 FPS.
- Upgraded environment delivers only ~8 FPS.
- The FPS reduction is observed during RTSP frame parsing/processing.
- We would like to understand whether the difference could be related to the NVIDIA driver/CUDA stack, GPU decoding, container runtime, Kernel, or other compatibility/configuration changes introduced as part of the upgrade.
Request for Guidance
Could you please advise what parameters/configurations we should compare or validate between the two environments to identify the source of this FPS degradation?
In particular, it would be helpful to know if there are any known performance considerations or compatibility issues related to:
- NVIDIA Driver ↔ CUDA compatibility
- GPU hardware decoding performance
- DeepStream/GStreamer RTSP pipeline performance
- Container runtime and GPU runtime configuration
- Kubernetes GPU device plugin/configuration
- Kernel changes affecting NVIDIA GPU performance
- GPU clocking, power management or throttling
- Decoder session limits or GPU utilization
- Any changes in the newer NVIDIA driver/CUDA stack that could affect RTSP/H.264/H.265 decoding throughput
Any guidance on the recommended diagnostics or specific parameters to compare would be highly appreciated.
Thanks,
Amit Jain
