FPS drops to zero with no error with USB camera
• Hardware Platform (Jetson / GPU) Jetson Orin nano
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2
• TensorRT Version
I am running a deep stream app on the Jetson via USB camera, the FPS drops to 0 after about each 1-2 hour of running without any error and I have to restart the module to continue running again for 1-2 hours. Does anyone have any idea.
Thank you
Can the camera still work when the FPS drops to 0?
Not sure if the issue is caused by the availability of the USB camera, you can use other programs to check if it can still stream (for example try gst-launch-1.0 v4l2src device=/dev/video0 ! xvimagesink).
You can also enable more logs by setting GST_DEBUG=3 ahead of the deepstream command line to get more logs.
