import cv2
import numpy as np
from PIL import Image
import tensorrt as trt
from torchvision import transforms
import labels # from cityscapes evaluation script
import engine as eng
import time
import inference as inf
#import keras
import argparse #import skimage.transform
import pycuda.driver as cuda
#import pycuda.autoinit
cuda.init()
cuda_device = cuda.Device(0)
cuda_ctx = cuda_device.make_context()
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
trt_runtime = trt.Runtime(TRT_LOGGER)
CLASSES = 1
HEIGHT = 720
WIDTH = 1280
new_frame = 0
prev_frame = 0
def preprocess(image):
# Mean normalization
mean = np.array([0.0, 0.0, 0.0]).astype('float32')
stddev = np.array([1.0, 1.0, 1.0]).astype('float32')
data = (np.asarray(image).astype('float32')/float(255.0) - mean) / stddev
return np.moveaxis(data, 2, 0)
def rescale_image(image, output_shape, order=1):
image=cv2.resize(image,output_shape)
return image
def main(args,frame,stream,context):
#input_file_path = args.input_image
serialized_plan_fp32 = args.engine_file
HEIGHT = args.height
WIDTH = args.width
#image = np.asarray(Image.open(input_file_path))
img = rescale_image(frame, (WIDTH,HEIGHT),order=1)
sp_im=img.copy()
im = np.array(img, dtype=np.float32, order='C')
im=cv2.cvtColor(im,cv2.COLOR_BGR2RGB)
#sp_im=im.copy()
im=preprocess(im)
t1=time.time()
#print(im)
#engine = eng.load_engine(trt_runtime, serialized_plan_fp32)
#h_input, d_input, h_output, d_output, stream = inf.allocate_buffers(engine, 1, trt.float32)
#print(h_input)
stream=cuda.Stream()
out = inf.do_inference(engine, im, h_input, d_input, h_output, d_output, stream,context, 1, HEIGHT, WIDTH)
t2=time.time()
print(t2-t1,"@@@@")
#print(out)
#print(out.ndim)
#print(type(out))
thr=out.max() * 0.65
#print(thr)
kmo=out* 255
kmo=kmo.astype(np.uint8)
_,thresh=cv2.threshold(kmo,int(thr * 255),255,cv2.THRESH_BINARY)
sp_im[np.where(thresh== 255)]=(0,0,255)
out_mask=np.zeros_like(out,dtype=np.uint8)
out_mask[np.where(out > thr)]=255
# cv2.imwrite("out_mask.jpg",out_mask)
cv2.imwrite(“out_img.jpg”,sp_im)
return sp_im,out_mask
if name == “main”:
parser = argparse.ArgumentParser()
#parser.add_argument(‘–input_image’, type=str)
parser.add_argument(‘–engine_file’, type=str)
parser.add_argument(‘–hdf5_file’, type=str)
parser.add_argument('--height', type=int, default= 720)
parser.add_argument('--width', type=int, default= 1280)
args=parser.parse_args()
output_vid = "output_rail.mp4"
fourcc = cv2.VideoWriter_fourcc(*'mp4v')
vid_shape = (1280, 720)
out = cv2.VideoWriter(output_vid, fourcc, 20.0, vid_shape, True)
#video_path = args.dataset
cap = cv2.VideoCapture("trim.mp4")
s1=cuda.Stream()
s2=cuda.Stream()
c1=engine.create_execution_context()
c2=engine.create_execution_context()
k=0
#with engine.create_execution_context() as context:
# context.execute(batch_size=1, bindings=[int(d_input), int(d_output)])
#context=engine.create_execution_context()
while True:
ret, frame = cap.read()
new_frame = time.time()
fps = 1/(new_frame-prev_frame)
prev_frame = new_frame
print(fps,"fps")
#time.sleep(0.020)
if ret:
if k%2==0:
segimg,segmask=main(args,frame,s1,c1)
else:
segimg,segmask=main(args,frame,s2,c2)
#segimg = cv2.cvtColor((segimg * 255).astype(np.uint8), cv2.COLOR_BGR2RGB)
segimg=cv2.resize((segimg).astype(np.uint8),(1280,720))
#segimg = cv2.cvtColor(segimg, cv2.COLOR_RGB2BGR)
out.write(segimg)
k=k+1
else:
print("end")
out.release()
cap.release()
break
