Fpv cam jetson
I need to connect an FPV camera to a Jetson Orin Nano. There are digital cameras like the RunCam MIPI, and there are analog ones. Analog cameras can’t be connected without a converter (please correct me if I’m wrong). Digital cameras, on the other hand, use different connectors, and I don’t understand why the MIPI connector looks different depending on the camera. Can you recommend something? I need to connect an FPV camera to the Jetson Orin Nano.
No other recommendation than that in Design Guide and reference design in DLC. Please read those docs first for custom camera design.
Thank you, I found the MIPI pinout for Jetson. I will continue experimenting. Which Jetson devices have analog ports?
