Hi! I am having issue running fq2bam on GCP using Nextflow, and the error message was not clear.
process PARABRICKS_FQ2BAM {
tag "$meta.id"
accelerator 4, type: 'nvidia-tesla-t4'
cpus 32
memory '196 GB'
machineType 'n1-standard-32'
disk 375.GB, type: 'local-ssd'
container "nvcr.io/nvidia/clara/clara-parabricks:4.4.0-1"
shell = ['/bin/bash', '-euo', 'pipefail']
input:
tuple val(meta), path(R1_reads), path(R2_reads)
tuple val(meta2), path(index_files)
tuple val(meta3), path(fasta), path(fasta_fai), path(ref_dict)
output:
tuple val(meta), path("*.bam") , emit: bam
tuple val(meta), path("*.bai") , emit: bai
path("*_duplicate_metrics.txt") , emit: duplicate_metrics
when:
task.ext.when == null || task.ext.when
script:
def args = task.ext.args ?: ''
def prefix = meta.prefix ? "${meta.prefix}" : "${meta.id}"
in_fq_command=""
for fq in `ls $R1_reads`
do
filename=\$(basename \$fq _R1.fq.gz)
read_group=\$(echo \$filename | awk -F'_' '{print \$(NF-1) "_" \$NF}')
sample_name=${prefix}
read_group_string="@RG\\tID:\${read_group}\\tLB:\${sample_name}\\tPL:Illumina\\tS
M:\${sample_name}\\tPU:\${read_group}"
in_fq_command+="--in-fq \$fq \${filename}_R2.fq.gz \"\${read_group_string}\" "
done
nvidia-smi
pbrun \\
fq2bam \\
--tmp-dir /tmp \\
--num-gpus $task.accelerator.request \\
--ref $fasta \\
--bwa-options="-Y -K 100000000" \\
--fix-mate \\
--optical-duplicate-pixel-distance 2500 \\
--out-duplicate-metrics ${prefix}_duplicate_metrics.txt \\
--out-bam ${prefix}.bam \\
\${in_fq_command} \\
--monitor-usage \\
--low-memory
The log below:
| NVIDIA-SMI 550.90.07 Driver Version: 550.90.07 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Tesla T4 Off | 00000000:00:05.0 Off | 0 |
| N/A 62C P8 11W / 70W | 1MiB / 15360MiB | 0% Default |
| | | N/A |
| 1 Tesla T4 Off | 00000000:00:06.0 Off | 0 |
| N/A 70C P8 12W / 70W | 1MiB / 15360MiB | 0% Default |
| | | N/A |
| 2 Tesla T4 Off | 00000000:00:07.0 Off | 0 |
| N/A 71C P8 11W / 70W | 1MiB / 15360MiB | 0% Default |
| | | N/A |
| 3 Tesla T4 Off | 00000000:00:08.0 Off | 0 |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
[PB Info 2024-Dec-09 21:02:05] ------------------------------------------------------------------------------
[PB Info 2024-Dec-09 21:02:05] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2024-Dec-09 21:02:05] || Version 4.4.0-1 ||
[PB Info 2024-Dec-09 21:02:05] || GPU-PBBWA mem, Sorting Phase-I ||
[PB Info 2024-Dec-09 21:02:05] Mode = pair-ended-gpu
[PB Info 2024-Dec-09 21:02:05] Running with 4 GPU(s), using 1 stream(s) per device with 16 worker threads per GPU
[PB Info 2024-Dec-09 21:02:15] # 0 0 0 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 4.4 CPUUsage%: 9.3
[PB Info 2024-Dec-09 21:02:25] # 0 0 0 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 4.4 CPUUsage%: 10.2
[PB Info 2024-Dec-09 21:02:35] # 0 0 0 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 4.4 CPUUsage%: 9.7
[PB Info 2024-Dec-09 21:02:45] # 0 0 0 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 4.4 CPUUsage%: 9.4
[PB Info 2024-Dec-09 21:02:55] # 0 0 0 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 4.5 CPUUsage%: 13.0
[PB Info 2024-Dec-09 21:03:05] # 0 0 0 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 4.5 CPUUsage%: 12.4
[PB Info 2024-Dec-09 21:03:15] # 0 0 0 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 4.5 CPUUsage%: 12.1
[PB Info 2024-Dec-09 21:03:25] # 0 0 0 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 4.6 CPUUsage%: 11.7
[PB Info 2024-Dec-09 21:03:29] Read 3171 alt contigs
[PB Info 2024-Dec-09 21:03:35] # 9 0 0 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 10.5 CPUUsage%: 26.2
[PB Info 2024-Dec-09 21:03:45] # 32 0 2 0 0 0 pool: 0 0 bases/GPU/minute: 0.0 CPUMem%: 20.1 CPUUsage%: 58.1
[PB Info 2024-Dec-09 21:03:55] # 48 0 2 0 0 0 pool: 0 341374699 bases/GPU/minute: 512062048.5 CPUMem%: 29.7 CPUUsage%: 87.0
[PB Info 2024-Dec-09 21:04:05] # 68 0 2 0 0 0 pool: 0 675766023 bases/GPU/minute: 501586986.0 CPUMem%: 39.7 CPUUsage%: 88.9
[PB Info 2024-Dec-09 21:04:15] # 88 0 1 0 0 0 pool: 0 1030785278 bases/GPU/minute: 532528882.5 CPUMem%: 49.2 CPUUsage%: 90.1
[PB Info 2024-Dec-09 21:04:25] # 100 0 2 0 0 0 pool: 3 1434780644 bases/GPU/minute: 605993049.0 CPUMem%: 58.2 CPUUsage%: 95.0
[PB Info 2024-Dec-09 21:04:35] # 100 0 2 0 0 0 pool: 3 1828946899 bases/GPU/minute: 591249382.5 CPUMem%: 63.2 CPUUsage%: 91.1
[PB Info 2024-Dec-09 21:04:45] # 100 0 2 0 0 0 pool: 1 2109108972 bases/GPU/minute: 420243109.5 CPUMem%: 68.3 CPUUsage%: 83.3
[PB Info 2024-Dec-09 21:04:55] # 100 0 2 0 0 0 pool: 4 2583584845 bases/GPU/minute: 711713809.5 CPUMem%: 72.2 CPUUsage%: 98.5
[PB Info 2024-Dec-09 21:05:05] # 100 0 2 0 0 0 pool: 2 3007016021 bases/GPU/minute: 635146764.0 CPUMem%: 75.6 CPUUsage%: 91.0
[PB Info 2024-Dec-09 21:05:15] # 100 0 2 0 0 0 pool: 1 3460339491 bases/GPU/minute: 679985205.0 CPUMem%: 78.2 CPUUsage%: 91.4
[PB Info 2024-Dec-09 21:05:25] # 100 0 2 0 0 0 pool: 0 3943597657 bases/GPU/minute: 724887249.0 CPUMem%: 79.8 CPUUsage%: 93.0
[PB Info 2024-Dec-09 21:05:35] # 100 0 2 0 0 0 pool: 0 4406859521 bases/GPU/minute: 694892796.0 CPUMem%: 81.6 CPUUsage%: 93.0
[PB Info 2024-Dec-09 21:05:45] # 100 0 2 0 0 0 pool: 2 4902733488 bases/GPU/minute: 743810950.5 CPUMem%: 83.9 CPUUsage%: 92.9
[PB Info 2024-Dec-09 21:05:55] # 100 0 0 0 0 0 pool: 2 5346113478 bases/GPU/minute: 665069985.0 CPUMem%: 85.6 CPUUsage%: 92.5
[PB Info 2024-Dec-09 21:06:05] # 100 0 2 0 0 0 pool: 4 5821960589 bases/GPU/minute: 713770666.5 CPUMem%: 86.8 CPUUsage%: 91.3
[PB Info 2024-Dec-09 21:06:15] # 100 0 2 0 0 0 pool: 2 6255280423 bases/GPU/minute: 649979751.0 CPUMem%: 88.5 CPUUsage%: 93.3
[PB Info 2024-Dec-09 21:06:25] # 100 0 1 0 0 0 pool: 2 6728588316 bases/GPU/minute: 709961839.5 CPUMem%: 90.1 CPUUsage%: 95.4
[PB Info 2024-Dec-09 21:06:35] # 100 0 2 0 0 0 pool: 2 7193228388 bases/GPU/minute: 696960108.0 CPUMem%: 91.9 CPUUsage%: 94.7
[PB Info 2024-Dec-09 21:06:45] # 100 0 2 0 0 0 pool: 2 7687705002 bases/GPU/minute: 741714921.0 CPUMem%: 93.8 CPUUsage%: 95.9
[PB Info 2024-Dec-09 21:06:55] # 100 0 2 0 0 0 pool: 2 8160975405 bases/GPU/minute: 709905604.5 CPUMem%: 95.6 CPUUsage%: 95.2
[PB Info 2024-Dec-09 21:07:05] # 100 0 2 0 0 0 pool: 3 8625665750 bases/GPU/minute: 697035517.5 CPUMem%: 96.8 CPUUsage%: 93.7
[PB Info 2024-Dec-09 21:07:15] # 100 0 2 0 0 0 pool: 3 9090324929 bases/GPU/minute: 696988768.5 CPUMem%: 98.1 CPUUsage%: 95.2
[PB Info 2024-Dec-09 21:07:25] # 100 0 2 0 0 0 pool: 2 9543563826 bases/GPU/minute: 679858345.5 CPUMem%: 99.0 CPUUsage%: 95.2
[PB Info 2024-Dec-09 21:07:36] # 100 0 2 0 0 0 pool: 3 9715519477 bases/GPU/minute: 257933476.5 CPUMem%: 99.3 CPUUsage%: 95.1
[PB Info 2024-Dec-09 21:07:47] # 100 0 1 0 0 0 pool: 3 9796550219 bases/GPU/minute: 121546113.0 CPUMem%: 99.5 CPUUsage%: 94.3
[PB Info 2024-Dec-09 21:07:59] # 100 0 2 0 0 0 pool: 4 9857649015 bases/GPU/minute: 91648194.0 CPUMem%: 99.6 CPUUsage%: 97.3
[PB Info 2024-Dec-09 21:08:17] # 100 0 2 0 0 0 pool: 4 9857649015 bases/GPU/minute: 0.0 CPUMem%: 99.8 CPUUsage%: 97.9
[PB Info 2024-Dec-09 21:08:32] # 100 0 2 0 0 0 pool: 3 9857649015 bases/GPU/minute: 0.0 CPUMem%: 100.0 CPUUsage%: 98.8
[Parabricks Options Mesg]: Checking argument compatibility
[Parabricks Options Mesg]: Read group created for /fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22F3KCLT4_5_R1.fq.gz and
/fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22F3KCLT4_5_R2.fq.gz
[Parabricks Options Mesg]: @RG\tID:22F3KCLT4_5\tLB:FDSANTIAGO_000032\tPL:Illumina\tSM:FDSANTIAGO_000032\tPU:22F3KCLT4_5
[Parabricks Options Mesg]: Read group created for /fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22F3KCLT4_6_R1.fq.gz and
/fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22F3KCLT4_6_R2.fq.gz
[Parabricks Options Mesg]: @RG\tID:22F3KCLT4_6\tLB:FDSANTIAGO_000032\tPL:Illumina\tSM:FDSANTIAGO_000032\tPU:22F3KCLT4_6
[Parabricks Options Mesg]: Read group created for /fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22F52VLT4_2_R1.fq.gz and
/fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22F52VLT4_2_R2.fq.gz
[Parabricks Options Mesg]: @RG\tID:22F52VLT4_2\tLB:FDSANTIAGO_000032\tPL:Illumina\tSM:FDSANTIAGO_000032\tPU:22F52VLT4_2
[Parabricks Options Mesg]: Read group created for /fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22GCWHLT4_5_R1.fq.gz and
/fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22GCWHLT4_5_R2.fq.gz
[Parabricks Options Mesg]: @RG\tID:22GCWHLT4_5\tLB:FDSANTIAGO_000032\tPL:Illumina\tSM:FDSANTIAGO_000032\tPU:22GCWHLT4_5
[Parabricks Options Mesg]: Read group created for /fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22GF53LT4_5_R1.fq.gz and
/fusion/gs/fq2bam-test/fqs/FDSANTIAGO_000032_22GF53LT4_5_R2.fq.gz
[Parabricks Options Mesg]: @RG\tID:22GF53LT4_5\tLB:FDSANTIAGO_000032\tPL:Illumina\tSM:FDSANTIAGO_000032\tPU:22GF53LT4_5
[Parabricks Options Mesg]: Using --low-memory sets the number of streams in bwa mem to 1.
For technical support visit https://docs.nvidia.com/clara/index.html#parabricks
Exiting...
Please visit https://docs.nvidia.com/clara/#parabricks for detailed documentation
Could not run fq2bam
Exiting pbrun ...
I am not sure what the issue is, as the error message did not provide any details other than exiting.
Can you advise on what the issue could be?
