Hello, thank you for the fantastic Clara Parabricks! I’m using clara-parabricks:4.5.1-1 with Nvidia Driver Version: 575.57.08 and CUDA Version: 12.9. The server is based on 2x AMD EPYC 9754 and 4x Nvidia L40 GPU, Ubuntu 24.04, NVME SSD, 512GB GDDR6. In general, the genomic pipeline works fine and is very fast, but sometimes when running fq2bam as part of deepvariant_germline, an error occurs:
[PB [31mError [0m 2025-Jun-22 20:56:49][src/internal/gpu_check_error.cu:22] cudaSafeCall() failed at src/internal/gpu_bwa_io.cu/82: invalid argument, exiting.
At the same time, fastq files and reference files are valid, and when re-running fq2bam, everything runs without errors.
Here are the deepvariant_germline launch parameters I use:
docker run --rm \
--name $SAMPLE_NAME \
--gpus all \
--env TCMALLOC_MAX_TOTAL_THREAD_CACHE_BYTES=268435456 \
nvcr.io/nvidia/clara/clara-parabricks:4.5.1-1 \
pbrun deepvariant_germline \
--ref $BWA_MEM_REFERENCE.fasta \
--in-fq $WORKING_DIR/$SAMPLE_NAME/fastq_L01_R1.fastq.gz $WORKING_DIR/$SAMPLE_NAME/fastq_L01_R2.fastq.gz \
--in-fq $WORKING_DIR/$SAMPLE_NAME/fastq_L02_R1.fastq.gz $WORKING_DIR/$SAMPLE_NAME/fastq_L02_R2.fastq.gz \
--out-bam $WORKING_DIR/$SAMPLE_NAME/$SAMPLE_NAME.bam \
--tmp-dir $TEMP_DIR/$SAMPLE_NAME/ \
--bwa-cpu-thread-pool 24 \
--out-variants $WORKING_DIR/$SAMPLE_NAME/$SAMPLE_NAME.deepvariant.vcf \
--num-streams-per-gpu 4 \
--gpusort \
--gpuwrite
I’d be grateful for any advice on how to resolve this error. Thank you!
