Some application dos resource loading in runtime which expect to slowdown rendering fps and just keep last rendering frame. (Local run without cloudxr is no problem )
CloudXR send a blinking/vibrating result look like it tries to keep FPS but sending several black frames or lost headset direction tracking.
Hi @huong - Apologies for the delay in response, are you still seeing this problem? Thanks!
Veronica
Yes, it is still there. However I can improve to reduce it almost by moving busy task to thread.
