Frame Lock with Quadro Sync on Lubuntu
I’m can’t enable GPU Frame Lock using the internal ribbon cables with Quadro Sync I card.
The computer specs are:
Model: HP Z820
CPU: (2) Intel® Xeon® CPU E5-2630 0 @ 2.30GHz
GPU: (3) Nvidia Quadro K5000
OS: lubuntu Alternate 64-bit 16.04.3 LTS
Driver: Nvidia 396.24
On the sync card, three Frame Lock sync status LEDs are solid amber indicating:
“GPU present but not synchronized”
as specified here: https://www.nvidia.com/docs/IO/146566/quadro-sync-user-guide.pdf
When I try to add a device through the Nvidia X Server Settings, I get the following error:
"Unable to add devices to frame lock group
Unable to connect to X Display ‘obj4-plt:0’ "
The X Display name is taken from the X Server Information under Nvidia X Server Settings.
Note, that I am able to a create single mosaic across all GPUs. Confirming to me that the connection is present.
Do you have any suggestions?
Well, its been a while, but i am struggling with exactly the same problem.
did you find any solution?
Johannes
Hello. Yes. It is more difficuly with Linux, but can be done.
From Nvidia Architect, Bill VanDyken:
While some of the attributes will persist, sync will not enable after a reboot without scripting it. Please refer to the documentation here:
http://us.download.nvidia.com/XFree86/Linux-x86_64/340.104/README/framelock.html
I reference the documentation because the driver, sync and GPU are very old and my description below may not be entirely applicable to your components.
Typically the method I use with current Quadro Sync II and Pascal Cards:
complete the display configuration and make sure the behavior is the way you want it in the final configuration.
Reboot the system to verify the config survives a reboot.
Then use the GUI to set up sync and verify there is no tearing or other artifact.
Run the command nvidia-settings -q dpys |grep -I connected # make note of the aliases for each display connector in use dpy:X and DP-X
dpy:X will be used with nvidia-settings from the CLI to set the attributes in your final script.
Run the command nvidia-settings -q gpus # this is the list of aliases for your GPU(s)
Run the command nvidia-settings -q -A |grep -I frame # this will be a long list of different framelock attributes and their current setting
Figure out the command syntax for nvidia-settings to set-up frame sync from the command line, then when you’re sure each component line works, build the script
The script you create should be similar to this example:
 ### Disable Frame Lock
nvidia-settings -c :0 -a :0[gpu:0]/FrameLockEnable=0
 ### Configure Frame Lock
nvidia-settings -c :0 -a “:0[framelock:0]/FramelockUseHouseSync=0” -a “:0[dpy:7]/FrameLockDisplayConfig=2” \
-a “:0[dpy:5]/FrameLockDisplayConfig=1” -a “:0[dpy:14]/FrameLockDisplayConfig=1” \
-a “:0[dpy:16]/FrameLockDisplayConfig=1” -a “:0[dpy:23]/FrameLockDisplayConfig=1” \
-a “:0[dpy:25]/FrameLockDisplayConfig=1”
### Enable Frame Lock
nvidia-settings -c :0 -a :0[gpu:0]/FrameLockEnable=1
