Title: Hard system lockup at uncapped framerate on Quadro P1000 via PRIME render offload — no kernel log, power button required
Environment:
- GPU: NVIDIA Quadro P1000 (Dell Precision 5530 laptop, Intel i7-8850H + UHD 630)
- Driver: [output of
nvidia-smi, top-left] - Kernel: [output of
uname -r] - Distro: Linux Mint 22.x (Cinnamon, Xorg)
- Offload setup:
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia, game renders on P1000, frames copied through iGPU for display
Summary:
Any OpenGL application running uncapped on the P1000 through PRIME render offload hard-locks the entire system — no keyboard response, no SysRq, no entries in the journal (it simply stops). Only a power-button restart recovers. Capping the framerate (in-game limiter or VSync) eliminates it completely.
Reproduction:
- Launch any GPU-heavy OpenGL app on the dGPU via PRIME offload with uncapped framerate.
- Generate sudden GPU load transients: fast chunk streaming (turning in circles loading terrain in Minecraft at 130+ fps), CS2 login (instant shader-compile/menu load), or a large in-game render-distance change.
- System freezes hard within seconds to minutes.
journalctl -b -1shows no NVRM/Xid/i915 errors — the log just ends.
Ruled out with evidence:
- Thermals: P1000 never exceeds 62°C under full load (repasted, custom heat-pipe mod); CPU in high 70s/low 80s.
- VRAM pressure: reproduces faster with shaders disabled (less VRAM, higher fps) — VRAM exonerated.
- Sustained load: card runs indefinitely at 100% in capped scenarios; only uncapped transients trigger it.
- Firmware: system BIOS 1.42.0 (latest per fwupd/LVFS), all firmware current.
- Hardware: the same physical GPU sustains ~982 fps uncapped in Minecraft on Windows without issue. This is Linux-driver-specific.
Notes:
The integrated UHD 630 never exhibits this at any framerate.
Suspect area: P-state/PCIe link power-state transitions in the Linux driver’s PRIME offload path under uncapped frame pacing.
nvidia-bug-report.log.gzattached. darkstalker@darkstalker-Precision-5530:~$ nvidia-smi
Wed Sep 23 11:16:42 2026
| NVIDIA-SMI 580.178.04 Driver Version: 580.178.04 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Quadro P1000 Off | 00000000:01:00.0 Off | N/A |
| N/A 33C P8 N/A / 5001W | 5MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1125 G /usr/lib/xorg/Xorg 4MiB |
darkstalker@darkstalker-Precision-5530:~$ darkstalker@darkstalker-Precision-5530:~$ sudo nvidia-bug-report.sh
[sudo] password for darkstalker:nvidia-bug-report.sh will now collect information about your
system and create the file ‘nvidia-bug-report.log.gz’ in the current
directory. It may take several seconds to run. In some
cases, it may hang trying to capture data generated dynamically
by the Linux kernel and/or the NVIDIA kernel module. While
the bug report log file will be incomplete if this happens, it
may still contain enough data to diagnose your problem.If nvidia-bug-report.sh hangs, consider running with the --safe-mode
and --extra-system-data command line arguments.Please include the ‘nvidia-bug-report.log.gz’ log file when reporting
your bug via the NVIDIA Linux forum (see forums.developer.nvidia.com)
or by sending email to 'linux-bugs@nvidia.com’.By delivering ‘nvidia-bug-report.log.gz’ to NVIDIA, you acknowledge
and agree that personal information may inadvertently be included in
the output. Notwithstanding the foregoing, NVIDIA will use the
output only for the purpose of investigating your reported issue.Running nvidia-bug-report.sh…
Detected driver type: Running RM Driver on GPUs
grep: /var/log/Xorg.0.log.old: binary file matches
complete.Summary of Skipped Sections:
Skipped Component | Details
ibstat output | ibstat not found
acpidump output | acpidump not found
mst output | mst not found
nvlsm-bug-report.sh output | nvlsm-bug-report.sh not found
Summary of Errors:
Error Component | Details | Resolution
