• Hardware Platform (Jetson / GPU) : Quadro RTX 4000
• Deep Stream Version: 6.0
**• Jetpack Version (valid for Jetson only) **
• TensorRT Version :8.0.1
**• NVIDIA GPU Driver Version (valid for GPU *: 470.161.03
**• Issue Type (questions, new requirements, bugs) **: questions
Hi Team
We are trying to delete the frame when the person is not in the frame. For that we are using nvds_remove_frame_meta_from_batch in the method of pgie_src_pad_buffer_probe.It is working for offline video but in rtsp feed its giving segmentation fault along with invalid memory Size, can you help us on that.
