I have a Jetson TX2 Dev Kit with L4T 28.1 installed. When I’m running the CUDA examples and or my own program I only reach a framerate of 30 FPS.
I can see that the CUDA examples are starting higer then the 30FPS but they are capped within the second to a stable 30 FPS.
I tried to adjust the vsync with the following command; “export __GL_SYNC_TO_VBLANK=0/1” to enable disble vsync but without any result.
I tried the ./jetson_clocks.sh script to increase performance but also no result. And even when I’m using the “nvpmodel -m” profiles I still have the same issue.
It looks like the fps is somewhere capped at 30 FPS.
Does anyone every experienced this?
Thanks in advance,
Rogier
UPDATE
So ok quick update. When I do the “export __GL_SYNC_TO_VBLANK=0/1” and then start the cuda example from terminal it does work! I then have like 500fps when vsynjc is disabled or 30 fps when vsync is enabled.
Only when I start the cuda examples by double clicking them they are always running in 30 fps.
Still any idea someone?
