The Jetson Orin Nano Super Dev Kit is a powerful device that can benefit from memory optimization, especially when running multiple services or applications. The user has successfully optimized the memory usage of their device by implementing several tweaks.
Firstly, they added a swap file to extend the virtual memory, which allows the system to use the hard drive as an extension of the RAM when it runs out of physical memory. This is a common technique to prevent the system from running out of memory and crashing.
Secondly, they disabled the unnecessary desktop environment, which can consume a significant amount of memory and resources. By disabling it, the user has freed up memory that can be used by other applications.
Thirdly, they disabled background services such as Bluetooth, ModemManager, and WirePlumber, which are not essential for the device’s functionality. These services can consume memory and resources, and disabling them can help to free up memory.
Lastly, they toggled NVIDIA services and Docker as needed, which suggests that they have optimized the usage of these services to minimize memory consumption.
The result of these optimizations is a significant reduction in boot-up memory usage, from an unspecified amount to about 450MB. This is a notable achievement, especially considering that the user has documented their scripts on GitHub for others to use.
In comparison to other Jetson devices, the Jetson Orin Nano is a relatively powerful device, but it still has limited memory and resources compared to more powerful devices like the Jetson AGX Orin. Therefore, memory optimization is crucial to ensure that the device can run multiple applications and services smoothly.
It’s worth noting that the user’s approach to memory optimization is a good example of how to free up memory by disabling unnecessary services and optimizing system settings. However, it’s also important to consider the trade-offs of disabling certain services, as they may be necessary for specific applications or use cases.
Overall, the user’s achievement is a great example of how to optimize memory usage on the Jetson Orin Nano, and their scripts can be a useful resource for others who want to achieve similar results.
