I’m using the FreeBSD 11 release (ftp://ftp.freebsd.org/pub/FreeBSD/releases/amd64/amd64/ISO-IMAGES/11.0/), but the drive points to FreeBSD 10.x - Current
Can I change the source code that this FreeBSD version 10.x - Current, to bypass and compile or will it impact and corrupt when installing the driver? (I have seen the licensing in the source code and I have knowledge that I must be authorized by nvidia for this.)
Is there a patch to fix this or is it obsolete and no longer supported
NVIDIA-FreeBSD-x86_64-319.17 (downloaded)
http://www.nvidia.com/object/freebsd-x64-319.17-driver.html
Compiling:
@:~/Downloads/NVIDIA-FreeBSD-x86_64-319.17 # sudo make
===> src (all)
machine → /usr/src/sys/amd64/include
x86 → /usr/src/sys/x86/include
awk -f /usr/src/sys/tools/makeobjops.awk /usr/src/sys/dev/acpica/acpi_if.m -h
awk -f /usr/src/sys/tools/makeobjops.awk /usr/src/sys/kern/bus_if.m -h
awk -f /usr/src/sys/tools/makeobjops.awk /usr/src/sys/kern/device_if.m -h
:> opt_acpi.h
awk -f /usr/src/sys/tools/makeobjops.awk /usr/src/sys/dev/pci/pci_if.m -h
awk -f /usr/src/sys/tools/vnode_if.awk /usr/src/sys/kern/vnode_if.src -p
awk -f /usr/src/sys/tools/vnode_if.awk /usr/src/sys/kern/vnode_if.src -q
awk -f /usr/src/sys/tools/vnode_if.awk /usr/src/sys/kern/vnode_if.src -h
cc -O2 -pipe -DNV_VERSION_STRING="319.17" -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -fno-strict-aliasing -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I/usr/src/sys -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -MD -MF.depend.nvidia_acpi.o -MTnvidia_acpi.o -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fwrapv -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -D__printf__=freebsd_kprintf -Wmissing-include-dirs -fdiagnostics-show-option -Wno-unknown-pragmas -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -Wno-error-pointer-sign -Wno-error-shift-negative-value -mno-aes -mno-avx -std=iso9899:1999 -c nvidia_acpi.c -o nvidia_acpi.o
In file included from nvidia_acpi.c:14:
./nv-freebsd.h:25:2: error: This driver does not support FreeBSD 10.x/-CURRENT!
#error This driver does not support FreeBSD 10.x/-CURRENT!
In file included from ./nv-freebsd.h:80:
/usr/src/sys/vm/vm_pager.h:125:2: error: implicit declaration of function
‘rw_assert’ is invalid in C99 [-Werror,-Wimplicit-function-declaration]
VM_OBJECT_ASSERT_WLOCKED(object);
/usr/src/sys/vm/vm_object.h:228:2: note: expanded from macro
‘VM_OBJECT_ASSERT_WLOCKED’
rw_assert(&(object)->lock, RA_WLOCKED)
/usr/src/sys/vm/vm_pager.h:125:2: error: use of undeclared identifier
‘RA_WLOCKED’
/usr/src/sys/vm/vm_object.h:228:29: note: expanded from macro
/usr/src/sys/vm/vm_pager.h:149:2: error: use of undeclared identifier
‘RA_WLOCKED’
/usr/src/sys/vm/vm_pager.h:172:2: error: use of undeclared identifier
‘RA_LOCKED’
VM_OBJECT_ASSERT_LOCKED(m->object);
/usr/src/sys/vm/vm_object.h:224:29: note: expanded from macro
‘VM_OBJECT_ASSERT_LOCKED’
rw_assert(&(object)->lock, RA_LOCKED)
5 errors generated.
*** Error code 1
Stop.
make[1]: stopped in /Downloads/NVIDIA-FreeBSD-x86_64-319.17/src
*** Error code 1
Stop.
make: stopped in /Downloads/NVIDIA-FreeBSD-x86_64-319.17
Best regards
Mauro Risonho de Paula Assumpção
https://br.linkedin.com/in/firebitsbr
