Noted a common build failure in recent driver package releases.
This happens for FreeBSD 13.0-RELEASE / FreeBSD 13-STABLE / FreeBSD 14-CURRENT, and the driver version series as noted in the Subject line of this post.
Namely:
" # make "
Results:
" In file included from nvidia-modeset-freebsd.c:12:
/usr/src/sys/sys/module.h:262:13: error: use of undeclared identifier ‘MAXPATHLEN’ "
The fix is easy. Edit the file:
" .src/nvidia-modeset-freebsd.c "
Find the line that says:
" #include <sys/module.h> "
And move this ^^^ line, well below the line that says:
" #include <sys/param.h> "
Save the modifications & compile. I’ve tested this on multiple different machines & compilation succeeds without issue.
I’d advise the NVidia dev team to include this simple fix as-is. One could opt for a more involved and complex set of checks & #ifdefs to the Makefile, but honestly, that’s just unnecessary work for no discernible practical reason.
Thanks for your continued FreeBSD support to all!
