Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.1.8175
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
I’m triyng to use the FreespaceDetector in our setup with 2 calibrated cameras.
The underliyng openRoadNet is initialized with a batchSize equal to DW_OPENROADNET_BATCH_SIZE_2.
The freespace module is initialized using the dwFreespaceDetector_initializeFromOpenRoadNet_new function by passing a dwFreespaceDetectorInitParams structure where the cam_new parameter contains the two handles to the cameras.
Then I use the dwFreespaceDetector_setCameraExtrinsics_new function to set the cam2rig transformations for the 2 cameras (in order to retrieve the free area in the vehicle reference frame).
The code stop when calling the dwFreespaceDetector_detectBoundary function with the error:
DW_INVALID_ARGUMENT: Freespace detector: number of frames must be equal to model batch size
How can I pass a batch of two images to the FreespaceDetector?
Thank you in advance!
