Hello everyone,
I know this is a common topic but even though I read multiple treads on the subject in Nvidia forums as well as in other forums I still can’t resolve it on my own.
The problem is that after installing NVidia Graphic driver the system hangs on login screen. I have installed multiple drivers using the standard Nvidia installer as well as kmod-nvidia repo but the result is always the same, freeze at login screen.
I’m attaching the output from nvidia bug report utility, hopefully it would help to find out where the error is:
nvidia-bug-report-log (991.0 KB)
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation TigerLake-H GT1 [UHD Graphics] (rev 01)
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
sudo lshw -c video
[sudo] password for support:
*-display UNCLAIMED
description: VGA compatible controller
product: GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list
configuration: latency=0
resources: iomemory:600-5ff iomemory:620-61f memory:81000000-81ffffff memory:6000000000-61ffffffff memory:6200000000-6201ffffff ioport:4000(size=128) memory:82000000-8207ffff
*-display UNCLAIMED
product: TigerLake-H GT1 [UHD Graphics]
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list
resources: iomemory:620-61f iomemory:400-3ff memory:6202000000-6202ffffff memory:4000000000-400fffffff ioport:5000(size=64) memory:4010000000-4016ffffff memory:4020000000-40ffffffff
