After kernel compilation, I changed the boot/Image.
It stops during booting with the following message.
What should I do?
============== message ============================================
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1445 bytes read in 149 ms (8.8 KiB/s)
L4T boot options
1: primary kernel
2: Custom 40-pin Header Config
3: FE-PI Audio Z V2
Enter choice: 3: FE-PI Audio Z V2
Retrieving file: /boot/initrd
5488163 bytes read in 357 ms (14.7 MiB/s)
Retrieving file: /boot/Image
** File not found /boot/Image **
Skipping FE-PI Audio Z V2 for failure retrieving kernel
1: primary kernel
5488163 bytes read in 356 ms (14.7 MiB/s)
Skipping primary for failure retrieving kernel
5488163 bytes read in 358 ms (14.6 MiB/s)
Skipping JetsonIO for failure retrieving kernel
SCRIPT FAILED: continuing...
Card did not respond to voltage select!
starting USB...
USB0: tegrausb: Invalid dr_mode 2 for host mode
probe failed, error -1
USB error: all controllers failed lowlevel init
BOOTP broadcast 1
DHCP client bound to address 192.168.0.204 (23 ms)
*** Warning: no boot file name; using 'C0A800CC.img'
Using eth_rtl8169 device
TFTP from server 0.0.0.0; our IP address is 192.168.0.204; sending through gateway 192.168.0.1
Filename 'C0A800CC.img'.
Load address: 0x83280000
Loading: *
TFTP error: 'File not found' (1)
Not retrying...
pci_hose_bus_to_phys: invalid physical address
missing environment variable: pxeuuid
Retrieving file: /boot/extlinux/pxelinux.cfg/01-00-04-4b-eb-f2-e9
*** ERROR: `serverip' not set
Retrieving file: /boot/extlinux/pxelinux.cfg/C0A800CC
Retrieving file: /boot/extlinux/pxelinux.cfg/default-arm-tegra210
Config file not found
starting USB...
BOOTP broadcast 1
DHCP client bound to address 192.168.0.204 (26 ms)
Filename 'boot.scr.uimg'.
Load address: 0x80200000
Loading: *
Not retrying...
BOOTP broadcast 1
Loading: *
Not retrying...
Thank you.
