Friction setting
I have found that when I load the objects onto the table, even without gravity, there is some moving between the table and the object. I am not sure whether it is because of the friction setting. Thank you.
Hi @ensu - In order to understand more, can you add some video of the issue you are seeing?
Also, did you try to adjust the friction setting from GUI?
