I was using the button headers and in retrospect I was unsure about what I was doing and supplied 12V to the FC REC (force recovery) pin on the jetson. I heard a pop and I’m pretty sure I fried something or maybe blew out a fuse. I can’t power if on with the barrel jack anymore as the green LED doesn’t light up. Does anyone have any ideas how I can salvage or fix the board? Worst case my SD card should be fine right?
Hi, this looks like some components broken since Power LED can not be turn on. SD card should be all right. You can try RMA for the board.
